Results 1 to 18 of 18
    Active Member Two Rings anthem's Avatar
    Jan 04 2007
    50cc Vespa
    CALGARY ALBERTA CANADA
    No brakes and stalling!
    Ok, so I'm driving home last night, and I notice my brakes aren't working, and the car has stalled. I slow down using the e brakes, restart, and the car want to stall unless i keep on the throttle. I manage to pull into an alley, but still have nothing in the brake dept. So, any ideas? At idle, it almost stalls, and bounces back up to about 1k. Am I f'd? Help!
    Mar 27 2008
    Charlotte
    Re: No brakes and stalling!
    Are the brakes just difficult to push, or do they not work at all? If they are just hard to push I would check the big vacuum line on the brake booster.
    Senior Member Two Rings Billasec4life's Avatar
    Jan 16 2005
    Earth
    Brake booster
    you would hear alot of air coming from back of the engine bay where the brake booster is, to fix you have to seal it for which there are various methods, search audiworld
    01.5 s4 "common" silver SOLD
    01.5 s4 Casa Stage 3 ....tuning.
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    I think theres a vaccum line from the brake booster to the engine somewhere... perhaps it got disconnected... you may wanna check the brake booster for any disconnected lines and trace them back to make sure its connected... if that line is disconnected, you probably have a big air leak which is why the motor keeps stalling, and you will have very little to no brakes at all..
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    look like it's around the famous F spyder hose
    Jan 04 2007
    50cc Vespa
    Is this something a normal shop can fix? I had to leave my car in a small ski resort trown, and towing it home is $375. There's a few shops there, but no audi ones obviously. And yes, I had to push as hard as I could to get any kind of braking.
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    You have a vacuum leak and a bad one. It could be at or near the brake booster, but in reality it could be any where in the vacuum system. I large enough leak will cause very poor idle and stalling and no brake boosting. It should be pretty easy to find with a pressure tester. You can even temporarily repair a vacuum line with electrical tape. just stay out of boost until it gets replaced. good luck and post the outcome so we can all learn from this!
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Dec 06 2007
    Calgary, AB, Canada
    Check the hose that goes into the firewall in the middle of the car. It's about 3/4" diameter. See if it's properly connected. On your car it will also go to the accordion hose. Check that spot as well. What town is the car in?
    Jan 04 2007
    50cc Vespa
    I had to leave it in Banff. Getting towed back today. Only $400, what a deal. I'm sure it's going to be an easy fix. I still want to see your stage 3 now the snows gone, and talk to you about doing mine. Whens good?
    Dec 06 2007
    Calgary, AB, Canada
    Dude you can call me and we can meet up and talk about it anytime you want. 690-7135
    Jan 14 2008
    00 S4
    Cranbrook BC
    Oh man I was just in Bnaff. Wish I could have helped. I have been carrying my pressure tester around since my last trip to Calgary where Jerbel had to help me lol. Yay for bad spark plugs and a bad N75 all at the sametime.
    Veteran Member Four Rings flips4's Avatar
    Oct 27 2006
    01.5&06 S4,04 MCS,08RangeRover, Ducati 848, YZ250F, and lots of TOOLS!
    Ocean Springs, MS
    i had the same problem, all of a sudden i had no brakes, horrible idle and i went through gas like a MO FO- like 1/4 tank just limping it home less than 1/2 mile away.
    you will see the like "about 1/2 inch solid black.. kinda shiny) comming through the top of your firewall to the right of the motor. follow that line down and where it connects theres a junction, its a 3 way. the line from the firewall plugs into this, i think you will find this to be disconnected or it blew out from the line, you can get some $3 silicone and run a bead around the top of the connection and shuv it back in. trust me it will work, and i believe that is your problem...
    hope that helps and sorry you had that hudge towing bill!!!
    If it aint broke... Dont fix it!
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    Quote Originally Posted by anthem View Post
    Damn it must be our crazy weather changes of recent because my car started doing the same thing on Sunday, brake pressure was fine then rock solid, then fine etc. etc. At idle it started stumbling and the dmn CEL pops up so got home looked under hood and sure enough that brake booster line connection behind the intake there had come apart, so just a little JB weld it's tip-top again, at least for now, damn Calgary weather!
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    Same thing happened to me a few weeks ago. Here's a link to a pic of the part for reference (and future searches). My JB Weld attempt was not so successful, but I used wire to keep the two pieces together until I got a new replacement part.
    http://forums.audiworld.com/s4/msgs/2707398.phtml
    Apr 05 2007
    Craig at Genuineaudiparts.com has good pricing on this item.. think it's around $70 or so from him.
    I think it's smart for any high mileage S4 to just replace as a wear and tear part, based on what i've been reading lately, and my experience.
    Jan 04 2007
    50cc Vespa
    Thanks for all the help! It was in fact that hose. Someone had replaced it before I bought it, and the clamp had come off. The fix was cheap,but the towing was not so fun. $525, for 132 kms. Now how am I gonna pay for my lapdances? Kidding, but thanks again to everyone.
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    I am having the same problem but I can NOT find anything disconnected back there. How do you do a pressure test on these cars?
    Josh
    Jun 14 2007
    2000 S4
    Connecticut
