Results 1 to 18 of 18
    Registered Member Two Rings john doe's Avatar
    Mar 07 2008
    2001.5 s4 Pearl White
    pa
    pressure test questions
    on a 2001.5 s4 when doing a pressure test with the awe Intake Pressure Tester , do i put this on right at the Y tube ? and is there anything i need to dissconect ?
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    Re: pressure test questions
    Take off the acordian hose, and hook it up there. Then on the Y pipe, there is a tube going off it towards the firewall, you need to cap that off. Also don't foget to unscrew your oil cap.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Mar 07 2008
    pa
    any quick ideas how to cap the tube to the firewall off
    Mar 07 2008
    pa
    ok got the hose blocked off that goes to fire wall , oil cap lose , when i start filling it up with air , air is comming out as fast as i put it in . is it suppost to build up with pressure ?
    Mar 07 2008
    pa
    sounds like comming out the turbos
    Senior Member Two Rings a4_1.8t_01's Avatar
    Feb 24 2008
    A4 1.8TQM 01
    Spray soapy water all over then put air in it and observe for bubbles.
    Unitronic tuned. love it.
    Need any services done in NYC area please PM me. I will diagnose and fix your car. Also do clutch replacements, Timing-belt services, Turbo upgrade/installation, Fluid changes, boost leaks and pretty much anything.
    Mar 07 2008
    pa
    should air build up or not
    Feb 24 2008
    A4 1.8TQM 01
    No it wont.
    Dec 17 2004
    US
    If air sounds like its not holding pressure, and its coming from the turbos, its prolly the fitting that goes to the charge pipe on the turbo. Mine did this same thing a while back and this is what it was. Sounds exactly the same.
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    couldn't it just be leaking through the exhaust valves? I did a test today on mine and it was holding pressure but slowly going down. we just asumed it was leaking through the throttle body and out the exhaust valves.
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Does anyone else hear bubbling sounds coming from the oil fill cap area when you pressure test?
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Mar 07 2008
    pa
    well i belive its not holding any pressure and going right through the turbos . are you using the boost gauge to check the pressure ? and where is this fitting , is it a hose with a fitting ?
    Mar 07 2008
    pa
    well no bubbleing but there in pressure in there becouse i can feel it if i tightin the can just a little
    Deactivated Four Rings
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Did you set the pressure regulator at about 30psi?
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    Quote Originally Posted by Jsmooth65 View Post
    yes...you should hear this (if there isn't a big leak somewhere).
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Jun 14 2007
    2000 S4
    Connecticut
    only do it up to 15. dont wanna put too much air through or you'll EF things up !. when i do mine, it holds all the air and sometimes the thing off the Y pipe the actual tester itself will want to come off.
    Aug 10 2007
    Castle Rock, CO
    Quote Originally Posted by S4Per View Post
    perfect thanks.
    I think people think that the pressure testing is like filling up a balloon and listening for a leak. Its not really the same thing. Your are passing pressure through the system, not filling it.
    Mar 07 2008
    pa
    ok thanks now i get it . i was thinking balloon thing .
