Results 1 to 3 of 3
    Sep 03 2007
    park
    FWD Coilovers on a Quattro
    So, I came across some coils on the forums but they were fwd, Oettinger Coils. So, I've searched the forums and one post came up. What I have interpreted is that the only difference between FWD Coils and AWD Coils for our Audi's is the spring rates.
    Is there a way I can change the coil over springs to make it work? I think Oetty Coils are modified KW's?
    Is there more differences?
    No one seems to do this but it might be worth it in this situation because there cheap.
    TY
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Re: FWD Coilovers on a Quattro
    I know that the spring rates are different between FWD and Quattro since the Quattro cars have extra weight in the rear. I bought my KW coils in the classifieds and found out later that they were for FWD. I bought new springs for $200 from KW -- problem solved.
    By the way, if you somehow end up needing the same springs that are used in the Variant 2 setup I have one extra Quattro rear spring.
    Sep 03 2007
    park
    Alright thanks for the hasty response!
    Because of that, I am picking up the oetty coils tomorrow. I think the Oetty's are KW's but I dont know which version.
    If its a match, i'll pm you.
