Results 1 to 16 of 16
    Active Member Two Rings voypa's Avatar
    Oct 15 2007
    New Jersey
    Thinking I Have a Boost Leak
    So I installed my GT71R kit this week and I got my ecu flashed with the Revo GTRS 550cc file. However, I've been doing some pulls and the peak boost I've hit is 14psi, and that was at 5000rpm. I've played around with my SPS3 to try and find a setting to fix this, but haven't been able to. Suggestions or ideas?
    REVO Powered 71r
    BetaAlphaTau Member # 24
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: Thinking I Have a Boost Leak
    Quote Originally Posted by voypa View Post
    Well shouldnt you check if you have a boost leak man? If you do problem solved. Youre a big turbo guy though so im sure you know how to check
    Sep 23 2006
    2002 A4 1.8TQ 5spd
    Do you have VAG-COM? You could check requested vs. actual boost.
    APR Stage 3+
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    2016 A6 3.0T, 2003 A4 1.8T Tip, GTRS Elim, REV0, 440 injectors, ASP front mount, etc Porsche 356
    What kind of tip are you running stock or neuspeed?
    Where did you get hte 550 file from?
    2016 A6 3.0T Stock
    2003 A4 1.8T Q TIP not stock
    Porsche 356 Stock
    Oct 15 2007
    New Jersey
    Im running the Neuspeed extreme. I got the 550 file from eurocode, its a revo file.
    REVO Powered 71r
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    If you are only hitting 14PSi most likely it is an issue with the N75 since that is what the wastegate spring is set at.
    If you have a boost gauge, try disconnecting the signal line from the wastegate and carefully do a pull, the turbo should make 25-30psi easily.
    ***try to be in boost only long enough to see if it spikes***.
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    ^ Like Greg said, sounds like the N75, go buy an EBC. Even if its not the fix, at least you'll have an EBC :-)
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STĂSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    The N75 issue can easily be ironed out, the new 550 file has very smooth throttle actuated boost too.
    Oct 15 2007
    New Jersey
    so you think I should just go pick up an ebc?
    REVO Powered 71r
    Oct 29 2005
    10speed
    San Francisco, CA
    No, seriously Colin you dont need one, I could tell you to go out and buy some HREs for your car because it will look nice with them, theres no need
    - Clint
    Feb 22 2007
    Auburn, WA
    I'm not familiar w/ the 550 program so if it is that much smoother than the typical 440 program then its not a huge deal, I just like the flexibility and if you're like me, I'm constantly adjusting mine. But if you dont NEED it, go buy HRE's like ^ he said
    Oct 15 2007
    New Jersey
    its not that I want an ebc, I just want my car to be boosting where it should be, so like 20-25 psi. and its not, so I'm trying to find a solution.
    REVO Powered 71r
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Did you disconnect the boost signal (small vacuum line) from the wastegate yet?
    Oct 15 2007
    New Jersey
    No I didnt, where is it located? Do you have aim or something so I can talk to you without posting every five seconds, lol.
    REVO Powered 71r
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    AIM = gsfowler
    Mar 11 2008
    B7RS4 & e46Ms
    make sure you've got the hard parts sorted before you start any sw correction...
    home-depot boost leak tester ftw!
