Results 1 to 39 of 39
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Weekend Goal: Install SB Stg 3 Clutch
    DAY 1 Progress
    So yesterday at about 5:00pm me and two friends started tearing apart my car to get the transmission out. We're using the DIY on audiworld, and I'm expecting it to take all weekend.
    Progress as of 1:30am last night:
    airbox/coolant tank out
    turbo to cat bolts off
    front axles unbolted from tranny
    pass. side heatshield (over the axle) out
    top 3 engine to tranny bolts out
    starter bolts out
    I snapped one T40 torx bit trying to get the driveshaft off, so we had to make a 1am walmart run to get a torx set. That was pretty fun.
    Here's where we are right now:
    I stripped one of the driveshaft bolts . One of the guys has a dremel at his house with a cutting wheel, so after he wakes up (that lazy ass), we're going to run and grab it. I'm hoping we can just cut a slot in the screw and use a screwdriver to turn it out. there's really not enough leverage to hammer a t45 torx bit into it.
    Today the plan is to get the transmission dropped, and get that clutch all bolted up. Maybe we can get it back in the car tonight but I'm betting that will happen tomorrow.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Re: Weekend Goal: Install SB Stg 3 Clutch
    good luck man. let us know how it works out.
    the homebrew'd s4
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by Kyle H View Post
    DAY 1 Progress
    starter bolts out
    You can use just a vise-grip to take that last bolt out. I had to do the same when a few of the front axle bolts stripped.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    I'm doin the same thing you are right now.. Only I am fighting rain and am by myself. AWESOME. goodluck with it.
    Oct 29 2005
    10speed
    San Francisco, CA
    hammer a bigger torx bolt into the driveshaft, should have used a swivel socket a plain extension wont work with the angle it gives you (which Im assuming you used)
    - Clint
    Veteran Member Three Rings DefiantS4's Avatar
    Jul 30 2004
    Houston, TX
    Bingo, vice-grips are awesome for stuff like this. I had to use them on the lower 2 engine-tranny bolts as well because I couldn't fit a wrench around the subframe.
    Past - '01.5 S4, APR Stage III
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Why are you using torx bits for those driveshaft bolts? Kragen (or autozone, whatever you guys have out there) sell those triple square bits for like 10 bucks...
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Q7, Q7, F-type manual
    Quote Originally Posted by sixfiveoh View Post
    what he said. even if it is stripped with the torx bit the triple square might still work.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Awesome, we'll try that next.
    Quote Originally Posted by njm23 View Post
    thanks man, goodluck!!
    because racecar.
    Jul 07 2004
    socal
    The bolts on my rear driveshaft are allen head.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    So I tried to throw some vice grips on that bolt, they just slid off the bolt when we tried to turn it. Then we used a grinder to make one of the sides flat (more grip!?), but it just rounded the edge of that side.
    We can't heat the bolt, I only have propane and I think it would damage the stuff around the bolt. The grinder is too big to cut a slot in the head of the screw for a screwdriver, so right now we're pretty stuck.
    I was thinking about using easy-outs, but I've heard horror stories of using those.
    Here's where we are now:
    because racecar.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    someone just had the idea on another forum of welding a piece of stock to the bolt, I think we're gonna try it. My friend with the welder will be here late tonight, I'll keep you guys updated!
    because racecar.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    the bolts strip out on a lot of people because beyond popluar belief, its not a torx bit its a tripple square hex bit.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by t1demont1 View Post
    It is a serrated 8mm hence why you stripped it.
    I suggest you replace all those bolts before you have a problem down the road.
    -18 718 GTS
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by Militant-Grunt View Post
    Well shit, I better email the guy who made the diy and have him fix that.
    because racecar.
    Jul 07 2004
    socal
    I wonder how well the GraBit tool would work.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Well we ended up being able to cut a slot in the stuck bolt and get it off with a screwdriver, woo.
    Right now everything is disconnected from the tranny, and we're ready to pull it out. We can't get the rear drive shaft disconnected from the rear of the transmission! Any advice on getting that out of there?
    because racecar.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    THE TRANSMISSION IS OUT!!!!!!!!!!!!!
    ....but we can't get the car high enough to roll it out from under the car....
    because racecar.
    Established Member Two Rings cleanandsimple's Avatar
    Sep 22 2006
    Lancaster, PA
    I never even took my tranny out from under the car. just move it out of the way so you can change the clutch. I even left it on the jack, made it really easy to go back in. Good luck
    Oct 30 2006
    B8 A4 Avant 6spd
    You're going to have fun putting it back in if you're doing this on jack stands.
    -18 718 GTS
    Jul 07 2004
    socal
    I have done it many times on jack stands and ramps. Only thing that is hard is trying to get the trans out from under the car. To do so you have to put the trans on the ground and jack up the car, hard part is getting the trans back on the jack to put it back in.
    Feb 27 2005
    North Wales, PA
    that m8 triple square is for the axles. you could have hammered a 6mm allen head on for the driveshaft
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    Yup I learnt the hard way too, stupid really as my bit set has the spline bits too.
    Glad she is out tho, i have to drop my tranny soon too as the six speed i put in is noisey as hell, god bless Ebay !!!
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Haha yeah ebay is a savior!
    Does anybody have the torque specs for putting the clutch back in? I can't find my bentley right now.
    because racecar.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    So we're running into some trouble trying to take off the pressure plate, we can't keep the engine from spinning!! any ideas?
    Here's something interesting I just found:
    because racecar.
    Oct 30 2006
    B8 A4 Avant 6spd
    If you have a big socket bolt for the crank up front, you can have someone hold it from spinning it. Then again your engine isn't out haha.
    Im sure there's another way to do it.
    -18 718 GTS
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Yeah we were able to get the 19mm 12pt socket on the front of the crank.
    Does anybody know what the deal is with that piece of metal hanging out cutting up my transmission casing? It sticks out about 3/8" from the flywheel/pressure plate.
    because racecar.
    Feb 27 2005
    North Wales, PA
    hhmm pull the pressure plate off and take a better pic.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Well I figured out what it was-- I snapped a bunch of crap!
    Think I had a lot of life left in this clutch?
    Annnd here's the old vs. new stuff:
    because racecar.
    Feb 27 2005
    North Wales, PA
    OH SNAP. good thing you are replacing the clutch. now that purchase is justified. =)
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Haha, definitely.
    I have a friend bringing over a flywheel for me tomorrow, hopefully I can get it all put back in by tomorrow night-- before 4am!
    because racecar.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Good progress man.
    I helped do this last week and I heard a tip. The engine should only be turned clockwise so when you hold the crank bolt to sustain the motor from turning, make sure it does not turn counter-clockwise.
    Nice choice in clutch too.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    What happens if you turn it the other way? I think I only turned it clockwise, but I could have turned it counter clockwise without thinking.
    Thanks.
    because racecar.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    So my friend just brought over a flywheel that he bought on ebay a couple of months ago, we were ready to put it in until we realized it's a little different....
    What the heck is this off of? I'm guessing it's off of a v6, but what do you guys think? The guy he bought it from said it's from a 97 1.8t.
    because racecar.
    Feb 27 2005
    North Wales, PA
    maybe its off a mk4 1.8t? Definitely not right though.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    It was out of a 1997 A4 [according to the guy on ebay].
    The part that's confusing me is that the new one is 8 bolt while my original is 6 bolt.
    because racecar.
    Feb 27 2005
    North Wales, PA
    no clue. whats the part number on it? it should be stamped somewhere on there
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    078 105 266A
    Does that look like a part number? That's the only thing I could find.
    Nevermind, it's a 12v flywheel off of a 97 A4.
    If anybody needs a 12v flywheel w/ clutch and pressure plate, my friends selling it for $79.99 + shipping!
    because racecar.
    thats a v6 flywheel.
    either 2.8 or 2.7t. not sure which one.
    but most anything starting w/ 078 is going to be a v6 part. or i should say, was originally a v6 part. you may find something w/ an 078 # that happened to make it on to a different motor. but def not a flywheel.
    contact via email please.
