Results 1 to 14 of 14
Thread: New S4 owner
    Active Member Two Rings Corey4.2's Avatar
    Apr 12 2008
    Phoenix AZ
    New S4 owner
    New to this forum and Audi and had a few questions. I want to do a few performance upgrades and needed some advice. To be honest the car does not pull as well as I thought it would so i want to know what I could do for around $3.5-$4k to give it that little extra kick. I was reading about GIAC and APR ECU and could not get a definitive answer on which was better. The car is a 2005.5 S4 TIP. My thoughts are to go with a chip, intake and exhaust. What are the typical gains for HP and torque when doing those upgrades and are the gains that noticeable. Also how hard is it to take off the front grill?
    Senior Member Two Rings momoney's Avatar
    Sep 20 2007
    Bellevue Wa
    Re: New S4 owner
    1.Welcome
    2.i would do the Giac chip flash and millteck exhaust and dont waste your money on a intake you can get BMC or K&N drop in filter stock intake is better.
    3.My guess on total gains in HP is around 35hp, and 38 ft-ib.
    4.Yes you will notice that your car is a beast now hahaha
    5.i dont know how hard it is to take the grill off maybe someone on here can help.
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    Re: New S4 owner
    Should have gotten a manual.
    Apr 12 2008
    Phoenix AZ
    Re: New S4 owner
    Yes, I know I should have gotten a manual. However the wife does not see it that way( she has kill the clutch in a jetta I had back in the day). It was going to be a automatic something might as well be the S4 :-).
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Re: New S4 owner
    I think S4's are awesome cars no matter how you cut it, but if you do some searching you'll learn that the gearing is not set up as well for acceleration on a tip compared to a manual.
    The automatic 335i/xi, however, is geared better for acceleration than its manual counterpart.
    I still think you made a good choice, just not totally performance oriented.
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Re: New S4 owner
    there is a huge diference between tip and manual on these cars. i wanted tip for the same reason but power loss was too much for me. with ecu flash main gain is going to throttle response. hp gains are very minimal. for exhaust you will have to go full back if you are looking at power gain.
    Apr 12 2008
    Phoenix AZ
    Re: New S4 owner
    I checked with a local shop and they wanted $400.00 to install the millteck catback. Is that a bit much for a catback install. So if i understand you correct a full exhaust would be the better way to go for performance gains? Thing I like about the giac is that if I'm not happy i get get my money back. What kind of gains should I see with a full exhaust system? Thx!
    Established Member Two Rings notachance's Avatar
    Sep 08 2007
    2005 B6 Audi S4
    North Jersey
    Re: New S4 owner
    That's too much. Look around you should be able to have a catback installed for around $200
    Veteran Member Four Rings ItzDarrellS4's Avatar
    Jul 14 2007
    A Sedan, a Hatch, a SUV, and a Pickup
    The Live Free or Die
    Re: New S4 owner
    Quote Originally Posted by notachance View Post
    or get some jackstands a friend and do it yourself. its very simple
    mpg's lol
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    Re: New S4 owner
    Quote Originally Posted by Corey4.2 View Post
    I got a quote of $80 from an indie shop. 4 bolts and hangers. You could DIY if you have stands and about 30-45 minutes.
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Dec 05 2006
    So. Cal.
    Re: New S4 owner
    $375 for dp and cat back install. they are charging you too much. in fact, just do the cat back yourself.
    Apr 12 2008
    Phoenix AZ
    Re: New S4 owner
    What Type of gains should I see with the millteck full system.
    Dec 05 2006
    So. Cal.
    Re: New S4 owner
    maybe 15 to 20. that's my guess as i can't confirm it.
    Oct 14 2007
    Mammoth Lakes, Ca
    Re: New S4 owner
    what will you gain? Some wicked sounds!!! Check out RAudi's old S4 with a full Milltek setup:
    http://youtube.com/watch?v=rp4QNesx18w
