Results 1 to 21 of 21
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    I hate car jacks....especially Audi's
    I used to think the widowmaker was actually a pretty ingenious design. Small, compact, seemed to work well. I jack up my car to do my brakes and put on the 269mm rears and I get the front end up, go to jack up the rear and the stupid jack makes the car shift! WTF!!! I try a few different ways to jack the car and the thing still freakin' moves! I wish I had a lift......SO much easier. Now I have to drain the clutch cylinder, lower the car, change the rear brakes, bleed the backs, lower the car, then raise it again to bleed the fronts.
    Anyone ever try a motorcycle jack under our cars? If it has the reach you could put it under the subframe, lift and support and then move to the back......
    05 allroad 2.7T Stock
    99.5 A4 1.8T K04 - Sold
    Senior Member Two Rings mainer0311's Avatar
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    Re: I hate car jacks....especially Audi's
    Widowmakers suck, they do their job, kinda, for a side of the road fix but you should never use one to work on your car. Your just asking for it. My a4 jetta was slamed and a jack wouldn't go under it. I found myself using the widowmaker so often I found one and welded a 1 foot square of steel on the bottom of it. That way it couldn't roll sided to side as easy.
    Coop
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    should be workin on level ground when jacking up the car and even if u'r on level ground, should always have u'r ebrake on and car in gear. when u need the whole car up in the air, do the front first so the ebrake holds the car from shifting. then do the rear. worse case scenerio, chalk the wheels with something.. i like to use old brake drums or rotors cuz i just happen to have alot of these around my garage
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    i love mine, use it all the time. only had it fall on me once, and that was bc i was trying to tighten the tire down while it was still in the air..dumb move
    2004 Subaru Impreza WRX
    Aspen White
    Veteran Member Three Rings black00A4's Avatar
    Oct 19 2006
    Ontario, Canada
    Why even bother with that thing, go to Canadian Tire and get a real jack with stands. It will cost you like $150 bucks and youll have it forever. Or if you dont want to spend alot of money just go to Princess Auto, I picked up two 3 ton jack stands the other day for $15. Its not worth risking your life or damaging your car with the factory jack.
    2000 Audi A4 2.8L Quattro Sport - Volcano Black
    Mods: 18" A8 Rep's, Ebay SS & Strut tower bar, PureMS Snub mount, K&N, MAF de-screened, H&R sports, STERN power ring & diff mounts, Cupra Lip, DEPO ecodes, Unitronic flashed ECU, Magnaflow
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    I don't bother using that thing. I tried it once and the car almost fell off. Now I just use my dad's Toyota jack and 3-ton jack stands.
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    I was using mine the other day and my car nearly fell over so the next day I went out and bought one of these.
    3000lb Harbor Freight Aluminum Racing Jack. I believe it was on sale for $75 and it only weights 24lbs
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by BONFIRE074 View Post
    thats one too many times.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Quote Originally Posted by MOFSTEEL View Post
    this and some jackstands is what you need. The jack included with the car is for emergencies only.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Quote Originally Posted by black00A4 View Post
    Princess Auto?
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Mar 28 2008
    ^lmao...
    Dec 14 2006
    Halifax, NS, Canada
    Quote Originally Posted by Stampy View Post
    Princess Auto?
    Its a Canadian store. Got lots of cheap tools, which are decent.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    I have a three ton craftsman jack that came with two 3 ton jack stands, a seat creap, and fender covers, it was on sale for $180 something, it works great, takes a few pumps to get up to load, but it will lift so much.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    034 Motorsports sells this little piece you can put onto a regular jack so you can jack it up from the same spot as the widowmaker.
    Jack and 2 jackstands should cost you more than $35
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Registered Member Two Rings dtapia_1392's Avatar
    Feb 19 2008
    West Chester, pa
    I was using my stock one too much and was afraid of it falling and damaging something so I just invested in a craftsman at sears hardware, it does the job.
    Feb 23 2007
    Burlington
    Oh....sorry guys....I didn't mean to misrepresent. I only use the widowmaker to jack up the car. I ALWAYS put it on stands. When I do jack it up it's always front first w/ e-brake on. But this time, when I was doing the rears, the car kept shifting. It was weird. I've never seen that before. I think the widowmaker was lifting the car on a funny angle.
    I used to have a hydraulic jack but it blew out on me after 1.5 years. I've debated about getting another one...the Michelin one would be nice. I'd still like to find a way to make a motorcycle/F1 type of jack.
    Mar 28 2008
    Not an Audi but I had the car fall off a Nissan jack when trying to put a spare on because of a flat when the car fell off the jack my foot was about 5 inches away from the rotor when it fell, however the rotor fell ontop of the tire I took off..
    My fault for not putting the e-brake on however.. ever since then I got myself some good jack stands and a good jack.
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    when changing a flat tire, take the wheel off and put it under the car next to the jack. if it falls off the wheel will catch the car and save your foot.
    Mar 28 2008
    It was kinda a tight spot I parked next to a curb I'm glad the tire saved it from sinking too low or it would of been a b**** to get a jack back under the car.
    Established Member Two Rings Accel's Avatar
    Jan 30 2008
    Vancouver
    At least it worked, my old Ford Ranger came with a jack that wasn't tall enough to raise the tire off the ground.
    Mar 28 2008
    all I can say is after all that happened I invested in wheel chocks and pull my e-brake just to be safe. Going to need to buy another jack since I got rid of it after I sold the Subaru.. Something with a decent jacking height... 13 1/2 inches was hardly enough to lift both rear tires on the Subaru lifting by the rear diff.
    I will never forget this as a little kid living in CA this nut (forgot who he was) I was riding with him and he got a flat and pulled the car over however it was on a slant and the passenger side of the car the grass sloped down to a small river. Well I was just happen to be walking away when I saw the car shift on the jacks towards me.. It never fell but it would of been the end.
