Results 1 to 3 of 3
    Active Member Two Rings trbo4's Avatar
    Nov 06 2006
    2000 A4 1.8T
    St. Louis, MO
    Broke off brass nipple going to intake manifold
    I was removing a leaking vacumm hose from the FPR to the intake manifold and the brass nipple snapped in half. Anybody have a idea on how to get it out?
    2000 A4 1.8T
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Re: Broke off brass nipple going to intake manifold
    You'll probably have to remove the plenum, to drift out the stub of brass nipple, and press a new one in.
    Don't be tempted to drill it out in situ, engines don't like metal filings.
    Good luck.
    Jun 04 2004
    fairfield cnty, CT
    there is a repair post on AW, someone did the same thing.
    they ended up making an identical looking nipple with some tubing and a swage tool.
    a bolt extractor should be able to remove the part that is still in there. if i were you, do all work with the manifold OFF the car.
