Results 1 to 2 of 2
Thread: turn signal
    Active Member Two Rings danski's Avatar
    Jan 21 2008
    2004 Audi S4
    Worcester, MA
    turn signal
    My front light blinker went out. I went to change it but see no easy way to access the bulb. I removed the intake pipe, but short of removing the air box I don't think I can get back there.
    Whats the best way to go about this? remove the entire headlight or air box?
    Thanks.
    Veteran Member Four Rings trexturk's Avatar
    Mar 20 2007
    '11 Sprint Blue S4, 03 996 Targa
    Chicago Burbs
    Re: turn signal
    just take off the headlight, there should be (4) torx bolts there, i forget the size.
    2 on top gotta come off and teh bottom 2 just loosen and slide the headlight out
