Results 1 to 12 of 12
    Senior Member Two Rings v.t's Avatar
    Mar 15 2008
    MN & IL
    Please Help! ESP Light.
    So, i have a little problem. It doesn't affect my driving at all but, sometimes just out of the blue, my ESP light comes on, just randomly. Should i be concerned or no?
    Example 1: I Was driving at night on a regular highway, the roads were fine and dry since it was sunny all day & all of a sudden, the light comes on.
    Example 2: I come home from school, pull in my driveway, then all of a sudden, the light comes on.
    Anyone know what is up with this? Thanks in advance for your help.
    Dec 06 2007
    Re: Please Help! ESP Light.
    Happens to many of us! Check ur MAF sensor! clean it! mine used to do it, i just changed my MAF recently and i'm set!GL!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Just happened with me. It's the brake light sensor. Replaced under warranty at the dealer.
    Mar 15 2008
    MN & IL
    Thanks for the tip guys!
    Dec 06 2007
    GQ9 can u please explain, the brake light switch or the stop switch under the pedal?
    -Kirk
    Nov 07 2006
    02 A4 1.8t
    New York
    According to my invoice. They rain fault-finding diagnosis. They removed the brake light switch, replaced it, cleared the faults. And everything was set.
    I had it VAG'ed before taking it to the dealer, and the code my shop told me that came up was the brake light switch. Apparently it's common to go bad.
    Dec 06 2007
    ^^ Should check mine thanx!
    -Kirk
    Senior Member Three Rings jonsaudi's Avatar
    Jan 09 2008
    2003 A4 1.8T tip quattro
    California
    So that's what it was! I had the same problem, ESP light on at random times. Not knowing it had to do with brake light switch, I picked up one up b/c my brake light was always on even with my foot off the brake pedal. Got one from VW dealrship for $13 and replaced it myself. Then ESP light problem was no more after that. I thought it just stopped out of the blue...
    Go with brake light switch really quick and easy fix. It even comes with a step by step instructions & diagrams...
    • 03 A4 B6 1.8T • Tiptronic • Brilliant Black • quattro • Sport Pkg //18" RS4 style rims //35% tint //Zimmermann x-drilled //Hawk HPS //CF wrapped trim.
    Mar 15 2008
    MN & IL
    Alright, I just might have to do that. Thanks Guys!
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    My B6 does this also, at least once a week, maybe more. IF it is the brake light sensor, does that mean the ESP is still deactivated when the caution/warning comes on?
    Nov 07 2006
    02 A4 1.8t
    New York
    Quote Originally Posted by KPC1.8TQuat View Post
    From what I hear it doesn't effect the traction control. But I would get it taken care of [O_O]
    Registered Member Three Rings a2a2pqk's Avatar
    May 16 2005
    05 A4 1.8T 6MTQ USP
    Richmond, BC Canada
    Funny. I just had this happen to me today as well.
    Actually first my battery died on me. Then when i jump started my car the light came on.. I thought it was just because my ECU went to sleep and it was a little crazy after getting jump started again. Then today when I was driving the Traction light came on again... Looks like I'll need to replace mine under warranty too! *However the light goes away after I turn the car off and then on again.*
    05 Brilliant Black A4 1.8TQ 6MT Ultra Sport Package - Premium, Ligthing, Sound(Bose)
    Performance Mods - REVO Stage2, Bosch Injectors(380cc), Forge 007 DV, K&N, APR Snub Mount, Turbo Timer, OEM DSMIC, Jet Jockey TIP, APR Stealth Exhaust
    Exterior Mods- S4 Rear Bumper, Oettinger Roof Spoiler
    Wheels/Suspension Mods - ABT Sport Springs, BBS CH
