Results 1 to 10 of 10
Thread: rattling noise
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    rattling noise
    So I went to go test drive a car yesterday 00 norgaro 6 speed.. The owner sayed the car needs a clutch kit bc it was making a rattling noise while driving. So I drove the car and I started hearing the noise while around 3.5k 4k and when I let off the gas I also heard it. It sounded like metal against metal. While I heard the noise I depressed the clutch to the floor and the noise went away. Any ideas what it might be? Does it sound like a throwout bearing?
    Established Member Two Rings DAP's Avatar
    Mar 16 2004
    Re: rattling noise
    Most likely the throwout bearing.
    Nov 07 2007
    New York City
    Re: rattling noise
    anyone else have any input?
    Dec 06 2007
    Calgary, AB, Canada
    Re: rattling noise
    Nope, he's probably right.
    Senior Member Three Rings Iosilver's Avatar
    Sep 20 2007
    2001.5 Slow4
    Winter Park
    Re: rattling noise
    Isn't this your 2nd test drive gone bad?
    Nov 07 2007
    New York City
    Re: rattling noise
    yes but The owner stated he needed a clutch kit just wanted to make sure it was the clutch and not the tranny..thanks for the info guys I just wanna make sure I know what im getting into before I do anything
    Feb 07 2008
    TX
    Re: rattling noise
    When you depressed the clutch did you hold the revs at the same amount, i ask because as soon as you normally depress the clutch the revs will drop and if it's something else causing the problem, i.e rev related then it will go away.
    Nov 07 2007
    New York City
    Re: rattling noise
    no when the noise came I depressed the clutch, the noise was gone and the revs dropped normally like they should..clutch wasnt slipping and shifted as it should and went into gear fine but it did feel a little more notchy then it should I think (btw no short shifter)
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Re: rattling noise
    Bad front CV joint on your main driveshaft.
    Cats burned it up.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Veteran Member Three Rings TalipseAWD's Avatar
    Apr 08 2007
    Stamford, CT
    Re: rattling noise
    Quote Originally Posted by Jsmooth65 View Post
    Cats burned it up.
    damn arson felines.
    2000 S4
