Originally Posted by
B18b1ex
Why do people always say this?
The pick up of your tank is in the bottom of the tank, any contaminants would get picked up anyway. People also say don't let the tank get empty because the water in your tank will get in your fuel lines, gas is lighter than water so if there was water in there you would also pick that up first.
Driving on empty
Do you pride yourself on getting every last drop of gas out of your gas tank before filling up? Cut it out.
Sediment from gasoline settles at the bottom of every gas tank. When you let your gas level run low, you force your car to use the dirtiest gas in its tank for fuel.
The lower your car's gas level sinks, the more the dirt gets stirred up from the bottom of the tank. Drive on a near-empty tank and you risk this dirt getting into your car's fuel line and even into the engine. There's a good chance your car's fuel filter won't be able to catch all of it, especially if you drive with a barely filled gas tank on a regular basis.
"You're going to pull the heaviest sediment into the fuel line," says Karl Brauer, editor-in-chief at Edmunds.com. "If it gets all the way to the engine, it could scar or damage internal parts of the engine."
If this happens, you're putting extra strain on the engine. And you'll need to flush the entire fuel system if it clogs up with dirt.
"You're talking a minimum of a couple of hundred dollars if it really jams up the system," Brauer says.
At the very least, you'll need to replace your car's fuel filter more often. That will run you about $100. And if sediment deposits or sludge form on your fuel injectors, you won't like the way your car drives.
"The car will run funny," says Tony Molla, a spokesman for the National Institute of Automotive Service Excellence. "It will feel like the car needs a tune-up."
The best advice? Never let your gas level dip too low.
"It's a good idea to keep your tank half full," Molla says.
citations: Lucy Lazarony,
http://www.bankrate.com/brm/news/auto/20031114a1.asp
