Page 1 of 3 123 LastLast
Results 1 to 40 of 81
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    SALE: B5 Podi package pre-sale!!
    OK... all you B5 guys have been waiting for this for a LONG time.
    So here is what I am going to do for you...
    I am offering $50 off ANY gauge package listed on this B5 pre-sale page-> http://www.podi.ca/Packages.aspx?CarID=6
    Some images on the page are obviously not B5 clusters and are there to show you what the gauges look like when installed.
    Enter this promotion code to get the discount: B5PODISALE
    The sale includes all gauges I have now AND the new 100% electronic stepper motor gauge that I have made. Here are pictures of the stepper motor gauge lit up at night
    If you only want just the steering column pod by itself the cost is $50 shipped! Click here to buy a B5 column pod
    IMPORTANT! When you place the order you WILL NOT get a package shipped to you until the pods and gauges arrive to me in May!
    This is why it is a pre-sale! This sale ends when the pods and gauges arrive. If you do not wish to accept these terms then please do not place an order at this time and wait for the gauges and pods to arrive.
    Senior Member Three Rings StuntManMike's Avatar
    Nov 19 2007
    01.5 S4, 350Z, H22 Hatch
    Around the corner
    Re: SALE: B5 Podi package pre-sale!!
    order placed.
    thanks
    Senior Member Three Rings AK1RA07's Avatar
    Dec 07 2007
    2001 S4, 1992 Miata, 1993 RX-7
    DFW
    OH DEAR GOD THANK YOU!
    Placing order now
    The boost gauge is electrical? I mean its obviously digital, but requires a electrical sender for the readout?
    Veteran Member Three Rings TRANS4M's Avatar
    02 Imola S4
    VA
    I'll order this when I get home!!
    Jun 11 2005
    Vancouver, BC
    Quote Originally Posted by AK1RA07 View Post
    Placing order now
    The electronic stepper motor gauge comes packaged with a boost sender.
    The digital VEI boost gauge comes with a boost sender built into it.
    The dual VEI digital gauge will require a separate boost sender that is powered by the gauge itself.
    Dec 07 2007
    DFW
    Quote Originally Posted by [email protected] View Post
    I ended up with the SW one anyway, I like the analog / mechanical setup.
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    WOW the VEI digital gauge looks awesome. I just recently bought a 60mm Defi boost gauge, but would definitely want your VEI digital gauge for the AFR and OIL psi reading. How accurate is the AFR readings? I was previously looking into the Innovate DB package with their o2 sensor, but am wondering if your AFR is comparable? Very interested!!!
    Jun 11 2005
    Vancouver, BC
    The AFR readings are only as accurate as the sender being used if paired with the VEI gauges.
    I package mine with the Innovate LC-1 which includes the o2 sensor so it is pretty much the same as their DB package but you get the ability to monitor a second reading.
    I have checked my LC-1 output to my boost/AFR gauge against the output via Logworks on the laptop and it is identical.
    Senior Member Two Rings Monster Stealth's Avatar
    Feb 27 2008
    99 A4 1.8TQM, 93 3000GT VR4
    Fort Wayne, IN
    Just placed mt order as well, can not wait to get this
    Thanks
    1999 Audi A4 1.8TQM - Daily Driver
    1993 Mitsubishi 3000GT VR-4 - Fully built top and bottom end, currently breaking in.
    Jan 09 2008
    VA
    PMed.
    Feb 17 2008
    2001.5 s4
    order placed thanks
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Got to support folks still building stuff for our B5's. My order will be placed ASAP. Thanks Winston!!!
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Veteran Member Four Rings Turtle's Avatar
    Oct 09 2006
    Thinking......
    Los Angeles, CA
    whats the difference between Stewart Warner package gauge and the Electronic Stepper Motor gauge package gauge???? I'm buying one of those setups
    2000 Audi B5 S4 WMS RS6 Stage 3
    *Rods
    F/S: Koni Adjustable Coilovers - BNIB -$1000
    Jun 11 2005
    Vancouver, BC
    There is quite a big difference between the Stewart Warner unit and the new stepper motor unit
    The Stewart Warner unit is mechanical gauge and it uses only one LED to backlight the dial and needle.
    The new stepper motor gauge is my version of a Defi gauge minus the brain to replace the Omori gauges I used to sell and it is more than a worthy replacement. It is 100% electronic so it will never buzz, uses a total of 9 LEDs to backlight the dial so it lights up as uniform as the OEM cluster dials, has peak memory, overboost alarm and is remote controlled.
    To use a VAG analogy the Stewart Warner is a Jetta and the stepper motor gauge is a R8. Both get the job done but one does it a whole lot better.
    Veteran Member Four Rings Rapter's Avatar
    May 01 2004
    2009 honda CRV
    Jersey
    Thank god you made the stepper motor one in grey to match the S4 because that's what I was buying no matter what. Now lets get these things in.
    Oct 09 2006
    Thinking......
    Los Angeles, CA
    well I dont like things (or people) that whine, beep, buzz, or otherwise make noise at me.... So I think I will be purchasing that there electronic device. SWEET!
    *Rods
    Active Member Four Rings NYCVR6's Avatar
    Queens, NYC
    PM sent
    Justin- 01.5' Pearl S4 24V VR6 Turbo Pow Pow
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Drive your car, not your dyno sheet
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    pm'd
    Veteran Member Three Rings ms4cd's Avatar
    Mar 23 2005
    Slow buckets
    Quote Originally Posted by jursch2211 View Post
    pm'd
    And another...
    Jun 11 2005
    Vancouver, BC
    All PM's replied
    Oct 09 2006
    Thinking......
    Los Angeles, CA
    hehe order placed....
    *Rods
    Jun 11 2005
    Vancouver, BC
    Thanks for the order.
    Jun 11 2005
    Vancouver, BC
    For those who have PM'd me... Here are some pictures of the electronic stepper motor lit up at night.
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    pm sent
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    Just pre-ordered... yay....
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
    Jun 11 2005
    Vancouver, BC
    You are going to love the dual VEI unit.
    Dec 13 2004
    allroad 2.7t
    san diego
    I hope the color in the pix does not do it justice... it looks orange... but all the other's look real red... i know, you don't make the gauges... but can't wait... (first week in MAY?)
    Jun 11 2005
    Vancouver, BC
    The color in the pictures is off. I don't know what setting I changed on my carmera but I haven't been able to get the red back to the way it was.
    The VEI red displays are the same red as the LEDs in your cluster. If it wasn't a perfect match I wouldn't run it in my own car.
    First week of May? That is what I am hoping for if there are no delays, but unfortunately the biggest delay will be with Canada Customs.
    Sep 20 2007
    norwich
    Order Placed for stepper motor package.
    now the waiting game continues for this and the ssautochrome exhaust!!!
    Sep 07 2007
    San Francisco, CA
    Hey Winston, will the electronic stepper gauges be compatible w/ the B6 setup?
    Established Member Two Rings bigverge's Avatar
    Apr 13 2007
    2000 Nogaro S4
    Toronto, Ontario, Canada
    Are there 2 different colour faces for A4 S4. Is the S4 face gray?
    May 01 2004
    2009 honda CRV
    Jersey
    Quote Originally Posted by bigverge View Post
    Good question I don't remember if I had to specify which color face I wanted. Winston can you update it if need be? I bought the electronic stepper one. I have a S4 so I would obviously want the grey face.
    Jun 11 2005
    Vancouver, BC
    Yes they are! That is why they have a white background & red needle color combination.
    I'll have a separate B6 sale when the gauges arrive.
    There is only one gauge face. While it is closely matched to the B5S4 the color of the dial is compatible with all other Audis. I tested the gauge dial color in B5,B6 & B7 A4's and it looks great.
    The S4 gray dial looks better than the original black dial when installed in our cars.
    Senior Member Two Rings CycloSteve's Avatar
    Apr 23 2008
    My Own Private Idaho
    Thanks Winston for a great looking package and for having the GB available to the forum...have just ordered mine, and can't wait to install it in my A4...as the PES G2 is being installed this week, so the timing is perfect!
    Steve
    2006 A4 2.0T Quattro Avant Manual - Let the mods begin
    2006 A4 2.0T Quattro Sedan Manual - Son's 2nd A4, well on the path to Stage 2+
    1998 A4 2.8 Quattro Avant Manual - PES G2, Milltek Exhaust, DTM 18x8's, Hotchkiss Swaybars, StopTech Stage II, PSS9 Coilovers, APR Snub, Podi, JHM SSK, Unorthodox LWFW, South Bend Stage 3
    Non-Audi Vehicles include multiple Landcruisers, Cayenne, BMW 335, trials and dirt bikes, M3 Euro-delivered from factory - SOLD and missed
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    How are the podi's coming?
    Josh
    Jun 11 2005
    Vancouver, BC
    The pods are completed, boxed and on a slow turtle on their way to me.
    Here are pics of the new stepper motor gauge installed in a B6. The lighting scheme is user selectable so for you S4 guys can just imagine it in reverse
    Review is here: http://www.audizine.com/forum/showthread.php?p=2506611
    May 01 2004
    2009 honda CRV
    Jersey
    Nice... Looks really good, but I'm like a kid on Christmas eve waiting for this damn thing LOL... Someone get that turtle a turbo or something.
    Established Member Two Rings JohnnyG's Avatar
    May 03 2008
    too many....my audi: a4 b8.5 project
    LongIsland, NY
    [[email protected];2465301]Yes they are! That is why they have a white background & red needle color combination.
    I can't wait that gauge looks PERFECT in the B6.....great job
    b5 too but I need a b6 one
    Veteran Member Three Rings ChumbaWumba's Avatar
    Jun 06 2007
    sum1 needs a new windshield
    neways...i placed my order in april...cant wait to set it up in my car
    02 Imola S4
    VA
    done.
