Results 1 to 3 of 3
    Dec 08 2007
    Whittier, Ca
    Coolant Temp Sensor(G83) & Tiptronic Switch (F189):
    I pulled the following codes:
    17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
    P1290 - 002 - Lower Limit Exceeded - Intermittent
    18161 - Tiptronic Switch (F189): Implausible Signal
    P1753 - 35-10 - - - Intermittent
    Anybody have experience with these problems or come accross any DIY or part #s? I looked around both here and AW for each fault code, but all i can find are bits and pieces of explanations...
    Dec 08 2007
    Whittier, Ca
    Re: Coolant Temp Sensor(G83) & Tiptronic Switch (F189):
    Anyone? Old Guy?
    Established Member Two Rings younga4's Avatar
    Apr 08 2007
    B6 A4 1.8t & MKIV 1.8t
    City of Angels
    17698- Coolant temp sensor needs to be replaced. I am not sure on the other sorry. I just found the same fault codes and I will be replacing this week I am sure you are good by now but if not, hit me and Casa and I will relay what worked the easiest. For right now i noticed when looking down into the engine bay it was on the bottom right part of the radiator, easily accessible after removing the belly pan. I can still drive but I hate its idling disposition right now. Peace.
    c.o.a.l.e.s.c.e.
    "We must find a new way to interpret our thoughts and feelings and reassess the extent to which our appraisal of our reality is realistic".
    Audentes Fortuna Juvat
    Young
