Results 1 to 7 of 7
    Established Member Two Rings mark_2328's Avatar
    Apr 04 2007
    Fargo, ND / Brainerd, MN
    Misfire/Bogging Down! HELP PLEASE!
    So my car started bogging down during boost when I go over about 1/2 throttle. It will just bog down for a couple seconds, then kinda fight through it and smooth out. Sounds really bad though, so I've been babying it ever since. I'm assuming its something with my air/fuel. Maybe a vac/boost leak somewhere? Would the O2 sensor cause something like this? My buddy says he doesn't think it sounds like a misfire, but I'm not sure. Not throwing a CEL, and I have VAG-COM, but haven't used it much and I don't have a laptop right now. When I do end up VAGing it, what should I log, etc?
    2000 S4, Autothority chip, H&R Sways, basically stock..
    Mar 20 2008
    Louisville,KY
    Re: Misfire/Bogging Down! HELP PLEASE!
    Quote Originally Posted by mark_2328 View Post
    Bro, theres about 10 of us with the same problem. Scroll down the list of threads, and you will find a few possible solutions.
    Apr 04 2007
    I don't think its that big of a deal, bro. If anything, it will help you out too. Settle down.
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    i vote for boost leak. doesn't seem you have a misfire, you didn't mention a blinking cel. get some pvc caps and tap in a pneumatic fitting. put it on your intake hose and pressurize to about 15-20 psi. just be careful on this leak tester i've launched a few pvc caps at myself for not tightening down the hose clamp. plus you can check vag for softcodes if you get misfires due to plugs/plug gap... good luck w/ your tests.
    Apr 04 2007
    I have a tester, just haven't had time to check it out. Would that cause it to bog down so much though?
    Jan 06 2005
    san diego
    hmm maybe, you might be leakin boost to atmosphere causing a rich condition. plugs black?
    Apr 04 2007
    Finally got it to throw a CEL. Misfiring on cyl 2 and random. Same thing that happened when the ICM took a shit on me. But would the ICM cause it to only misfire under boost? Tried another coilpack but that didn't do anything. I'll try new plugs today, but I don't think that will do anything either. I'm running out of patience for this.
