Originally Posted by
Jerm
So I'm getting my sludge problem fixed by Audi. The dealer said they are replacing some hoses and seals. Then flushing the engine. I've seen posts of other people getting a full engine replacement due to the sludge problem. Should I be worried about any other internal damage or just be happy with what Audi is doing?
don't worry they inspect your engine for any damage, If they find none then you didn't have any. The cleaner is hardcore 6qts run for 30min @ 3000rpm.They replace your oil pump pick-up, oil feed line (turbo) ,most of your crankcase vent pipes (plastic & rubber) ,pcv valve, reseal your oil pan and replace your valve cover gasket. They will also replace the cam tensioner if found to be worn.
