$80 SHIPPED
4X30 watts at 4 ohms (stereo)<BR>2X120 watts at 4 ohms (bridged)
One end of the amplifier is home to 2 sets of line-level inputs and open set of line level outputs that can be used to drive another amplifier, as well as a set of speaker level inputs for use if your radio does not have line-level outputs. Also contains active crossover controls, with seperate front and rear gain and x-over point controls, along with a "QBASS" bass-boost control.
The other end of the amplifier is the "business end." This end contains (2) 20 amp fuses, power, ground, and remote turn-on leads, a status LED, and four speaker outputs.
I believe I have the manual at home but will have to look for it. The manual is avaliable online from PPI's website at: http://www.precisionpower.com/ppipdf...ps/ppi45c1.pdf
Amplifier came out of my old car, worked well when installed, used to drive my surround speakers.
