Results 1 to 8 of 8
    Active Member One Ring sammytown's Avatar
    Mar 26 2008
    2007 Audi S6
    Eastside / Puget Sound
    Will these fit my '07 S6 + Opinions Please
    Hi All - I'm just starting down the path of some mods to my newly acquired 2007 S6. I picked up a lightly used set of KW v3 coilovers (not installed yet) and am looking the Antera 365 wheels you see pictured below.
    Two things:
    1. Will they fit? As you’ll see in the picture, the wheels are 9.0J x 20FH et = 30. Mounted on them are Michelin PS A/S tires (255/30 ZR20). The seller had them on his S4 and says he purchased them from someone who had them on a ’07 S6. But, I can't get in touch with the S6 owner to confirm.
    2. What is your opinion on the looks / aesthetics? These wheels apparently go for $2k each...the seller is extremely motivated and is selling the wheels with the tires for a fraction of that.
    Thanks,
    Sammytown
    2007 S6 - Brilliant Black over Black, Tech pkg, leather dash, AMI, heated rear seats. Mods: 19" HRE 591Rs, KW variant 3 coilovers, Ventureshield bra, 35% tint all around, hardwired V1
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Will these fit my '07 S6 + Opinions Please
    All our 20" wheels are ET 42 or higher and would run a 275/30-20 (XL). I don't see how that setup ever went on an S6, as that tire size can't meet the load requirements for the S6 front axle (its about 100lbs short per tire)
    Good price, but not a good deal imo
    Mar 26 2008
    2007 Audi S6
    Thanks, Doc. This is very helpful. Just so I understand, the issue is both with the fit of the wheel (sounds in this case the offset is wrong) as well as the tires aren't at a high enough load rating? Just want to confirm if it's both or just the tires that are the issue.
    Thanks again,
    Sammytown.
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    I would check out Rennworx RSL wheels, in the anthracite finish. I think that the style and the color would set your car off nicely. Good luck.
    Apr 14 2004
    rs4, ruf, rs7
    L.A./Vancouver
    s6 deserves a better wheel IMHO
    Mar 26 2008
    2007 Audi S6
    Hey guys - thanks for the feedback. I won't be picking these up as they don't fit (et 30 would have sticking out too far) and I agree the look is just "off".
    Doc - thanks for the size / load info.
    Sammytown
    Oct 06 2006
    South Bend, IN
    No problem !
    Veteran Member Three Rings gotdubd's Avatar
    Sep 28 2006
    Hell.
    Quote Originally Posted by Quattroownsyou View Post
    my thoughts exactly.
    that car is way to pimperish to have antera wheels.
