Results 1 to 12 of 12
Thread: GT25R kit?
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    GT25R kit?
    What do you guys think of this:
    http://www.autospeedperformance.com/...t25R/GT25R.htm
    The power numbers seem low to me, and RS4 IC's? Shouldn't something bigger be used? Where are better GT kits?
    Senior Member Two Rings quickdub's Avatar
    Jul 06 2005
    1973 Mustang Conv.
    CA/NJ
    Re: GT25R kit?
    IMO this is the best kit, but also the most expensive. Take a look at their FMIC upgrade, with Oil cooler. Pretty slick if you ask me. Also, remember these numbers are on pump gas, and they are with a conservative tune.
    If you are as lucky as me, to have taken a ride in his first build-up... it was AMAZING!
    Mark is a super knowledgeable guy... if I lived closer (and had a shit ton of money) there wouldn't be a question who I'd go to.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Re: GT25R kit?
    Quote Originally Posted by quickdub View Post
    So thats why the numbers looked low... hmmm. I'd have them tune it for some good power and not be conservative. But thats just me.
    Veteran Member Four Rings lrg8683's Avatar
    Nov 01 2005
    S4
    VA
    Re: GT25R kit?
    40k later and bam.. GT25's on your S4.
    -Luis
    Feb 17 2008
    Ottawa Ont.
    Re: GT25R kit?
    hehhehe
    thats about the size of it.
    Stellar quality, but they dont seem to perform like they should.
    Vag stuff makes 475-500whp on pump gas with theirs.
    Jul 06 2005
    1973 Mustang Conv.
    CA/NJ
    Re: GT25R kit?
    ASP's 492 whp seems comparable to VAG's... And that was done on a bone-stock motor. Mark's car is much more built...
    I think reliability is underrated around here, especially when you spend these kinds of bucks on a vehicle... i could care less if i'm 20 hp less than optimal, if it means my rods and pistons will be staying together.
    Aggressive tunes lead to knock, which lead to rods snapping, holes in pistons etc etc... and then the day its extra hot and humid, and you get a less than optimal tank of gas, your engine blows.
    Aggressive tunes only belong on cars running 100+ octane on the track, with trackside support if you ask me.
    GT25's make these cars fast enough without being on the ragged edge.
    Just my $.02 To each his own.
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: GT25R kit?
    440cc injectors? How are those not maxed out...?
    Stage 3+ RS6's
    Feb 17 2008
    Ottawa Ont.
    Re: GT25R kit?
    They are.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: GT25R kit?
    Looks sweet but you can buy a S4 for that much. I would love to get it, but you can get a well set up K04 for around $6k, my car is a dd and premium 91 oct pee water is $4.09 a gallon around here :( But if I had the money to burn, why not.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 11 2006
    Boston
    Re: GT25R kit?
    You can piece together a higher quality kit for a third of the cost.
    Just look around with the innovation of GT products these days. Quality will outshine
    Stage 3+ RS6's
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Re: GT25R kit?
    Look in the classifieds, I got a Vag motorsport kit complete with fueling for sale.
    Fueling an turbos are used, but in perfect condition.
    The rest is all new.
    Pm me for a very good price if your interested in a 470whp beast at a price of a k04 or even an Rs6 kit.
    Mar 11 2008
    north east
    Re: GT25R kit?
    X2. friend wouldnt go near that car. he would have bought it on the spot.
