Results 1 to 31 of 31
    Veteran Member Three Rings chrisbostonusmc's Avatar
    Jan 12 2008
    Sarasota,Fl
    Put the car on the lift and look what i found!
    sorry for all the pics but is it normal for a stock 2.7t 6speed to be this leaky at 68k??
    Stage 3 SSP Tuned RS4 K04'd
    12.4 @ 115 on pump gas only
    425AWHP/467AWTQ
    ALL MY MODS DONT FIT IN SIG! DAMMNITTT!
    95 Toyota Supra T51R 800hp
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    Re: Put the car on the lift and look what i found!
    wow those pictures are horrible lol I don't even know what I'm looking at!
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Jan 12 2008
    Sarasota,Fl
    sorry I was at a garage and all I had was the camera phone. They are of two areas. Looks like a rear main seal leak and possible leak around the turbos somewhere. Those are the hoses around the turbos that are on the bottom
    425AWHP/467AWTQ
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    The bottom of all my cars look like that.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Oct 29 2005
    10speed
    San Francisco, CA
    no it should not be leaking... are you sure its comming from that spot? that would be your transfer case and I would just pull the cover off, get some sealant, and ure fine... Although getting to those bolts may be a bitch and i stripped one of mine
    - Clint
    Jan 12 2008
    Sarasota,Fl
    Im having my timing belt service done this weekend so i will get a better view and find the source..on a positive note, I saved a lot of hp by switching to german castrol today and alot on my car insurance by switching to geico last week
    425AWHP/467AWTQ
    Feb 17 2008
    Ottawa Ont.
    Quote Originally Posted by chrisbostonusmc View Post
    I switched to Geico to get my advertised free handjob. But those bastards didnt tell me it would be from a man.
    Apr 05 2007
    it's hard to tell from the pictures, but what ocean did your car sink to the bottom of?
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    rear main crank seal?
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Quote Originally Posted by jungb5s4 View Post
    that is my guess...
    directions:
    clean area thourghly with brake cleaner and rags.
    then dump in a couple ounces of florecent oil die(into your oil cap)
    drive for a good 100+ miles.
    take it to a shop and have them shine their black light on it.
    from there you will be able to see exactly where the oil is coming from. or if it's just a residue from something else.. but i got money on rear main seal. just an fyi, it's a $40 part. but it's about $800-1000 in labor from the dealer.
    good luck
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jul 07 2007
    Tempe, AZ
    yeah ^... it's a lotta labor for a gay part. good luck with it.
    mine was leaking right there as well, upon further inspection it turned out to be my Cam plug seal that was leaking. still a hella ton in labor though
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    well there is no leak there cause thats where the clutch goes its a dry area, its like that from engine sludge build up and when u drive your car it moves around or you have a leak elsewhear and it moved its way there i had that on my car when i took out the engine, tranny, all you got to do is clean the whole bottom end and then inspect the underneak for any leaks
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Jan 12 2008
    Sarasota,Fl
    Thanks guys! Another S4 member on here is doing my timing belt service this weekend so we'll find the source. I appreciate the help guys!
    425AWHP/467AWTQ
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by AMC83189 View Post
    it may be intended to be a "dry area". but that does not magically stop oil from leaking there. trust me. the rear main seal will leak, and it will seep to that area(as well as many other things can leave residue there)
    Current:
    Previous:
    Jun 15 2007
    Quote Originally Posted by sean1.8t View Post
    true not gonna deny that cause mine was dirty in there
    but it wouldnt do that much he would have noticed his clutch slipping if that much got in there
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Sep 17 2006
    SLC, UT
    just depends on how long this leak has gone un noticed. it's pretty probable actually
    Current:
    Previous:
    Jan 12 2008
    Sarasota,Fl
    My clutch is in great shape...as of right now, slave cylinder was just replaced on it though
    425AWHP/467AWTQ
    2000 s4
    Fairfield, CT
    its your cam tensioner seals. looks like a rear main seal but its not and the other is your output shaft seal in the trans. ALL very common and not too difficult to do. great flat rate job cause the book says 4 hour per tensioner seal and 3 for the output shaft seal so unless you have 1000 bux to drop try it yourself
    i heart my s4
    2000 s4
    Fairfield, CT
    the right side tensioner drips down the back of the head around the tranny and looks likke the rear main. but always start highest up when doing oil leaks. so vc gaskets and tensioner seals should be your first start. the left on drips down the front of the block and onto the IC pipe. the output shaft seal drips onto your cats
    i heart my s4
    Jun 14 2007
    2000 S4
    Connecticut
    hey, LOL i think your signature isnt working bc we dont have images in our sigs like AW. i think thats where your issue is. Post a liink to the pic not a image file. ya knowwwwww.
    Jul 07 2007
    Tempe, AZ
    Quote Originally Posted by rms-s4 View Post
    That's the same thing that happened to me.
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    if it's an s4,we dont use haldex awd system,thats VW. we use torsion i believe...but i could be wrong...
    Jan 12 2008
    Sarasota,Fl
    Quote Originally Posted by EuroSteez View Post
    Thanks! I learned someone new
    425AWHP/467AWTQ
    Registered Member Two Rings
    Feb 24 2004
    MS3
    Austin
    You are correct. It's called torsen, which is tor-sen, which is short for torque-sensing.
    Feb 17 2004
    Sterling, VA
    Next time you have the belly pan off, check the rear edge of the oil pan. The oil pan doesn't have an actual gasket, it just gets sealed with silicone sealer and assembled. If the oil pan is leaking back there it will blow all over the place under the car. One of the most obvious places is that area where the engine mates to the tranny (as you showed). The triangular vents in the belly pan funnel air right past that path and creates a nice spray of oil mist at certain times. As for it getting on the turbo outlet pipes, the pictures you have shown, have oil on the hoses but there are no visible signs of oil on the turbo itself and if the turbo were leaking oil, it would be more visible at the gasket between the turbine and the downpipe.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Jan 12 2008
    Sarasota,Fl
    UPDATE!: Had the bumper off today and looked around, all my seals are good. Turns out that it is a busted spider hose... That thing is a piece! At least its cheaper!
    Jul 07 2007
    Tempe, AZ
    i dont think they could have chosen a more brittle plastic than found on that hose
    Aug 10 2007
    Castle Rock, CO
    Mine has turned into hard plastic brittle crap as well. Where are you getting your new one from?
    Jan 12 2008
    Sarasota,Fl
    Quote Originally Posted by Jsmooth65 View Post
    probably the dealer
    Active Member One Ring desmo888's Avatar
    Apr 12 2008
    2001 S4, 1995 S6, Ducati 750SS
    Elizabethtown, PA
    probably the dealer
    There is a guy a AW B5 S4 forum that sells Audi oem parts for 20% over cost. sorry - I should look for a link but its late and I am tired.
    p.s. I kind of like this Audizine. Every post does not start with "yo yo yo" or "s'up".
    First post virgin but long time Audifans thick skinned poster.
    Jan 12 2008
    Sarasota,Fl
    Quote Originally Posted by desmo888 View Post
    Well we all bought German cars so we have some level of intelligence!
