Results 1 to 37 of 37
Thread: S4 vs RS4
    Senior Member Two Rings isb's Avatar
    Jun 21 2007
    Michigan
    S4 vs RS4
    It looks as if the current market for a loaded 2007 S4 is ~$40k. A 2007 RS4 with premium package looks to be possible for $10-15k more.
    An RS4 in this neighborhood would just be affordable for me currently.
    Is it worth it to stretch?
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Re: S4 vs RS4
    Yes.
    Dec 05 2007
    992 911, C8 RS7, Citroen 2CV
    Naples, FL
    Re: S4 vs RS4
    Look in the forum as this has been addressed many times.
    If you can truly afford the extra 15K, top performance is a major factor, and you will keep your car for while, then RS4 is your answer. It is truly an amzing car. I lapped it at the LeMans circuit in France against the R8 and there is not that much difference.
    If it is strectch financially (even a little one), then the S4 will give you 90% of what the RS4. The interior is the same and the exterior is subjectively very similar (only the fanatics like us will say "wow, this is an RS4").
    Now, if money is truly not an issue and you don't need a stick, I would seriously consider the new C63. It is seriously faster than RS4 for everyday use.
    Good luck and let us know what you end up with
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Re: S4 vs RS4
    if its a stretch then the answer is no. if you don't have to stretch to get there...then the answer is yes.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Veteran Member Three Rings NewImageS4's Avatar
    Dec 07 2004
    2007 RS4
    SE PA
    Re: S4 vs RS4
    I think it's more like 15 to 20k more..
    I don't see many RS4's selling for less then 55k.
    And yes worth every penny IMO. Some would say otherwise.
    Past cars:
    99.5 A4 1.8
    01.5 S4
    04 A4 1.8 Ultra Sport
    04 S4
    12 S4
    12 Golf R
    15 SQ5
    17 SQ5
    14 RS5
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Re: S4 vs RS4
    you are talking about used right? new S4's are like 60k when you get off the lot...
    either way the difference is about the same when you're talking about the price between the s4 and rs4
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Re: S4 vs RS4
    Quote Originally Posted by isb View Post
    I think you should go for the RS4 for sure. I would do it if I could.
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Dec 20 2006
    CAN
    Re: S4 vs RS4
    Never stretch to buy a vehicle that depreciates. My rule of thumb is that a vehicle should not occupy more than 10% of your after tax income yearly. Following a strict rule like this would keep many people out of financial trouble. One of the best ways to lose money is to buy an expensive car, figure out after the fact that you can't afford it, and then take a huge loss on depreciation and fees.
    If it's easily affordable, there is simply no choice. RS4.
    emilyPay.com - Revolutionizing payment processing by making transactions simple, secure, and more reasonably priced.
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Re: S4 vs RS4
    Quote Originally Posted by CanuckRS4 View Post
    Are you saying that you gross $700K if you bought a $70K RS4? Maybe I'm missing something
    For myself, the insurance and gasoline costs are the deturances for purchasing an RS4. On the other hand if I or someone else could trully afford and RS4, insurance and gasoline should be irrelevant costs.
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Senior Member Three Rings snowbird's Avatar
    Nov 20 2007
    '04 S4, '11 Q5, '90 Corrado, '96 911 C4S
    Toronto ON
    Re: S4 vs RS4
    Quote Originally Posted by belinko View Post
    Fuel consumption is approximately the same for the S4 and RS4, thanks to FSI in the RS.
    Veteran Member Four Rings EuroB6's Avatar
    Nov 24 2005
    2019 Audi Q7 2019 Audi Q8 2017 911 GTS
    New Jersey
    Re: S4 vs RS4
    i think he means..add up each month's payments for one year and dont exceed 10% of your income.
    2020 Audi SQ7 PremPlus | Navarra Blue|Black|Black Optic Package
    2024 Audi Q7 PremPlus|White|Beige|Black Optic Package
    2017 Porsche 911 GTS Black | GTS Interior Package | Numeric shifter | GT3 RS Skirts | Kline SS Headers, Kline 200 Cell Cats, Kline SS Exhaust | Full Car PPF | 20” BC Forged MLE81 | Michelin PS4S |TechArt Springs | Vektor Performance Oil Separator | BMC Air Filter
    Jun 21 2007
    Michigan
    Re: S4 vs RS4
    Yes, I was looking at used. The year 1 depreciation hit is just too painful.
    I did look for old postings, but an "S4 vs RS4" search can't be done as there's a 3 character minimum on search strings.
    If someone knows where to point me, I'd appreciate it. Otherwise, it appears that the consensus at this point is RS4 is worth the stretch if you can afford it. Could someone elaborate a bit?
    I assume the 10% guideline is depreciation + interest + insurance + maintenance + fuel < 10% of after tax income?
    If $60k were financed @ 5%, that's ~$1,200 pa interest starting out. Figuring 15% depreciation = $3,600 pa, $2,000 pa insurance, $500 pa maintenance & $2,500 fuel comes to just under $10k pa. So, income after tax >$100k & no problem?
    Nov 24 2005
    New Jersey
    Re: S4 vs RS4
    try like used 2007 S4 for 50k, maybe HIGH 40s and used RS4, low 60k and very high 50k..i saw a sweet RS4, with NO navi for 56k, 14k miles, but it was sold.. these cars depreciate a lot and within another year or two, I bet youll be able to get great deals on the RS4.
    Established Member Two Rings Rossi15's Avatar
    Mar 03 2008
    2014 Phantom Black Pearl Effect Audi RS5
    Columbus
    Re: S4 vs RS4
    Yea, I just got a 2006 S4 18k miles CPO for 42k. These cars hold value pretty damn well. A low mileage 07 will be at least 47k or so.
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Re: S4 vs RS4
    used 07 RS4 are still listing between 62k and 68k give or take. mileage is between 4k and 20k. so nothing is really gone down on them.
    and its just like i said. forget the math. if your stretching yourself to get the car. then you shouldn't be getting it. this is very simple. sure i can pay more and sacrifice "X" or multiples of "X" and then get an RS4 and be strapped down or B, get an S4 and not be strapped down and sacrifice nothing. not a hard decision here.
    The RIDES:
    AMA Member
    JHMFTW!!
    Veteran Member Four Rings JetBlue's Avatar
    May 03 2004
    Carlsbad
    Re: S4 vs RS4
    I see a lot of RS4's in socal for less than $60K all will less than 20K miles. With 20K miles you should be able to get $55K
    "The American Republic will endure until the day Congress discovers that it can bribe the public with the public's money." Alexis de Tocqueville
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Re: S4 vs RS4
    then i need to buy things in socal cuz in chicagoland area...i see some at 68k USED!!!
    The RIDES:
    AMA Member
    JHMFTW!!
    Registered Member Two Rings
    Jan 22 2008
    calabasas
    Re: S4 vs RS4
    lol belinko shure stuped him.. that 10% factor is retarded.. people making a million a year have like 5 cars sitting in their drive way if not more- USUALLY not saying they should.. in my viewing experience
    Senior Member Two Rings S4str's Avatar
    Jan 12 2008
    Northern, VA
    Re: EMERICR put it very well...great car, but if....
    your stretchin' the budget, the RS4, isn't worth the extra $10-15K. In day-to-day driving, you won't notice that much of a difference. That said, if you're willing to pay the price of entry for a very exclusive car, go for it.
    Nov 24 2005
    New Jersey
    Re: S4 vs RS4
    buy a Cayman S, you can enjoy that for day to day driving :) I just love those cars...sorry.
    Jul 21 2004
    South Florida
    Re: S4 vs RS4
    Quote Originally Posted by b00st View Post
    Yikes, you could pay to have one transported to you for cheaper...
    I've seen some 2007 Audi RS4 cars for the mid 50s ($53,000 to $55,00) with less then 20K on them. I see McKenna Audi has a CPO one for 55 grand so you'd get a longer warranty then buying one new (6 year and 100K miles). Hmm, ok, ok, I have to stop myself from buying one :)
    2018 Audi S5
    Gone-
    Dec 20 2006
    CAN
    Re: S4 vs RS4
    I was assuming he was leasing/financing the purchase. A straight out cash buy depends on your situation of course. If you have 60K cash in the bank waiting to be used, and it's not needed for living/savings etc...then i think you can easily afford the car and should go for it.
    Dec 05 2006
    So. Cal.
    Re: S4 vs RS4
    I actually looked at almost all the preowned Audi's in the Los angeles area and gotta say that they were worked. Two at the Auto Gallery in Woodland Hills which were priced below $60k were not worth it. The white one had bubbling paint on the valve covers and the salesman said that it had been run real hard. The other Daytona Gray one had the transmission out and they were working on it even though they advertised it on the net as "For Sale".
    McKenna here in L.A. had a blue one that had 29k on the clock and they wanted 59k. It was ok but still had some wear and a scratch on the front bumper.
    Rusnak in Pasadena had a black one that had a ton of scuff marks on the drivers side rocker and a scratch on the drivers door that isn't coming out, asking 66k.
    The seats on all of them had wrinkled driver's side bolsters.
    I was so picky that I just bit the bullet and got a new one.
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    Re: S4 vs RS4
    So why no pics anywhere ?
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    Re: S4 vs RS4
    I notice mine has some wrinkles, how do you avoid that? Jump in the car?
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Nov 24 2005
    New Jersey
    Re: S4 vs RS4
    Quote Originally Posted by channad View Post
    climb in through the sunroof, unless you have the sunroof delete option, you'll have to crawl from the trunk and jump in front..
    Apr 27 2004
    Re: S4 vs RS4
    Quote Originally Posted by EuroB6 View Post
    No, no no ! You have to remove the seats and put those really nice A4 seats in until you're ready to sell the car OR if you're fortunate enough to be tall just use the rear seat
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Veteran Member Three Rings Speedymon's Avatar
    Aug 27 2005
    2004 S4
    San Antonio, Tx
    Re: S4 vs RS4
    I prefer just to enjoy the comfy seats. but yeah those wrinkles suck.
    Quote Originally Posted by Stevelev View Post
    Imola_Jon's supervisor...
    Apr 27 2004
    Re: S4 vs RS4
    Quote Originally Posted by Speedymon View Post
    LOL ! I was kidding ... after looking for over a year for S4 seats for my BT A4, I switched gears and bought my S4.
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Aug 27 2005
    2004 S4
    San Antonio, Tx
    Re: S4 vs RS4
    Oh i know you were kidding lol.
    Oct 03 2007
    B7 S4, Kia Cadenza, Kia Optima
    Orange County, CA
    Re: S4 vs RS4
    We bought a warranty called perma-plate. I can get the wrinkles out fo free...
    Nov 27 2006
    07 RS4-E63 M6-07 A3 2.0T
    San Diego
    Audi RS4 | Mugello Blue on Black | Premium Package | Valentine 1 | SOLD
    Audi A3 | Ibis White on Black | DSG | S-Line | Cold Weather | Open Sky | Audi Navigation | Technology Package | Premium Sound | APR Stage 2 | GHL Exhaust | KWV2 | Neuspeed Intake | APR Fuel Pump | Hotchkis Sways | AWE Vent Boost Gauge Soon | Blackout S-Line Grille | JL Audio Full Sound System | EuroJet FMIC Soon | Weight Reduction | SOLD
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Re: S4 vs RS4
    Thanks for clarifing.
    So basically you'd need to be making in and around $100K+ to afford a new RS4. That makes more sense
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Re: S4 vs RS4
    The wrinkles are called patina some would say that it's an indication of "real" leather as opposed to faux leathers. My CPO car has some, but after using leather treatment I was able to clean out the wrinkles and they stand out less than they used to.
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Re: S4 vs RS4
    Quote Originally Posted by ChronicTeutonic View Post
    Sorry for the thread jack, but what leather treatment did you use? I'm noticing it too on the driver's side.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Apr 11 2008
    Pasadena, CA
    Re: S4 vs RS4
    I used 1Z Lederpflege : http://www.1z-usa.com/leather_care.html
    I tried Lexol and it left the seats feeling sticky and dull. The 1Z feels smooth and appears have more sheen, but nothing excessive.
    I got mine from Super Autobacs in West Covina they carry most of 1Zs products, think there's a store in OC too...
    The Avant Garde
    Dec 05 2006
    So. Cal.
    Re: S4 vs RS4
    I'm using the Zymol leather conditioner with really good results. I'll take a pic of my seats at 2k miles and post how they have been holding up.
    As far as getting in the car, I like to go with the Dukes of hazard style.
