Results 1 to 10 of 10
Thread: need a clutch
    Q7, Q7, F-type manual
    need a clutch
    Ok, so I am looking for a clutch for my 2.8. After 120k (30k supercharged) I think my clutch is about to give up the ghost. Car is daily driven in DC and blown right now. So I want something driveable that will wear well but that can take a beating at the track. I have plans for big power in the future. I have pretty much settled on a Spec 2+ or Southbend 3. I like that the spec has a higher torque rating. I will probably forgoe the whole LWFL as I spend half my time driving slogging around under 2500 rpm and don't want to hear the chatter (unless someone can convince me it wont be that noticeable). I am open to recomendations one way or the other.
    Finally, anyone aware of any good deals on this stuff? Thanks in advance.
    Feb 27 2005
    North Wales, PA
    Re: need a clutch
    Quote Originally Posted by audispeed View Post
    you can barely hear the chatter over and exhaust. You can go either way on the LWFW. I like mine. I would skip the spec 2+. The southbend stage 3 is good. Slightly stiffer pedal over stock. The stage 4 is pretty stiff but after an hour your are used to it.
    Re: need a clutch
    Unfortunately southbend only goes up to stage 3 on the 2.8 (rated for 430 ftlbs). The spec 2+ is full faced and rated for 550 ftlb. So that plays into my decision. I am also considering going with an S4 fidanza flywheel and other clutch, but I need to double check the fitment first. Also, I dont mind a stiff pedal at all. Its the on/off feeling I want to avoid.
    Jan 25 2006
    A4 2.0T
    MD
    Re: need a clutch
    Whatever you do.. Please do not get Spec.
    Re: need a clutch
    Quote Originally Posted by Don Supreme View Post
    I was under the impression that the problems had been resolved long ago. No?
    97 A4 2.0TQM
    Rochester, NY
    Re: need a clutch
    It's one of those things where something bad happened to a few people years ago and other people who haven't actually experienced the issue themselves keep relaying the message over and over again...
    Feb 27 2005
    North Wales, PA
    Re: need a clutch
    i've seen it in person twice. The face of the material came off the clutch disk completely. Spec did not replace it under warranty. My friend switched to southbend. They other one was in a jetta where it lost a rivet.
    Re: need a clutch
    Ok, so any ideas of where to get a good deal on the southbend?
    Btw, I feel like such a noob asking this question. I have seen so many of these threads. Searching didn't help much though regarding deals.
    Senior Member Two Rings slayerrule's Avatar
    Nov 02 2006
    50 trimming
    sloatsburg, new york
    Re: need a clutch
    i can help
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: need a clutch
    I can get you either SB or Spec, just let me know exactly what you want.
