Results 1 to 28 of 28
    Established Member Two Rings caall99's Avatar
    Oct 02 2007
    Boston Area
    Exclamation Aftermarket Headlights
    Could anyone point me in the right direction to getting new headlight assemblies for my 2000 S4. All i have found are a bunch of OE replacement designed for the H7 bulb (NON-HID). I am looking for an OE look or after market headlight assemblies that will fit my factory HID equipment and give me a great "beam cut-off". I would rather not spend the 500 or so on OEM replacements.
    eBay has a ton of ricerish after market headlights but some just look like crap and others i worry about the beam cut off for my hid bulbs, since i think most of those assemblies are made for the H7 bulb. Anyone have any input to this?
    Veteran Member Three Rings lsc2g's Avatar
    Jan 07 2006
    S3%2C%20Q8
    Calgary, Alberta, CANADA
    Re: Aftermarket Headlights
    i'm pretty sure its Ecodes or don't bother.. the ebay lights are crap
    the FK have angel eyes and are crap
    you can get cheap depo ecodes but are made for halogen h7s..
    so yea OEM Ecodes or nada.
    www.eurodrivers.ca
    Calgary Canada Euro Club
    Oct 02 2007
    Boston Area
    what is the main reason the ebay ones are crap? i really can't shell out that much money on headlights right now. i was hoping somewhere around 300 for both. OE are 450 a pop...
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    ive heard you can get the ebay ones but they need to be resealed ..but dont quote me on that one
    Oct 02 2007
    Boston Area
    if i was to get the ebay ones, would i have to replace certain parts within them from my old HID headlight assemblies? can anyone link me to depo (?) headlights that i could use for my factory HID balasts and bulbs? Is there a write up anywhere? Tell me what you guys did.
    Registered Member Three Rings Charlie's Avatar
    Sep 16 2006
    West Haven CT
    I have Depo's, There Great, I love them. I had to modify the housing slightly to fit the HID's, I ordered H7 HID bulbs and I was good to go. Alot of Splicing and soldering tho
    |Stage 2+ B5 S4|
    FOR SALE
    Jan 07 2006
    S3%2C%20Q8
    the ebay ones have very crapy sealing from my reading on the subject and the lenses are not that great.. and the wire harnesses are just junk.. but could depend on which ones you get too
    the depo are your best bet for clear corners and a good look
    really i think you could probably take apart your stockers and put parts into a set of ebay ones tho
    www.eurodrivers.ca
    Oct 02 2007
    Boston Area
    now the big question is, where do i find these depo lights??? and what part would i need to transfer? do the h7 depos have cutouts for the balasts on the back? i am very new to this car, which i am sure you can tell. i come from turbo 240sx's and mk3 supra turbos, so i know cars, just not audis
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    why not get some halogen ones and swap the plastic lenses? wouldn't that be cheaper and you can do the cc mod at the same time.
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Oct 02 2007
    Boston Area
    well here is the problem, my drivers headlight is destroyed. small accident that killed (cracked and chipped) the plastic lens on it. I haven't inspected the internals yet, but i know it still works fine. passenger side is fine, but i want something to replace both of them with.
    Sep 16 2006
    West Haven CT
    I have a Driver side Housing for sale if you want it. 100 plus shipping, its yours they are OEM euro with the clear corners.
    |Stage 2+ B5 S4|
    FOR SALE
    Oct 02 2007
    Boston Area
    Well i would need both headlight assemblies if yours is different from the US spec stock HID headlights. Dunno where i could find the passenger euro code assembly all on its own to match yours. So the solution to my problem is to just get the depo headlights for about 300 bucks, use some of the existing HID components i already have in my factory HID healights, and call it a day? now where can i pick up these depo headlights???
    Sep 16 2006
    West Haven CT
    I got lucky and I found mine on ebay, But there around .... Make sure you order H7 HID bulbs allong with the housings, Your going to have to splice the wiring to the Hid Connector. But otherwise its a pretty straight forward swap.
    |Stage 2+ B5 S4|
    FOR SALE
    Oct 02 2007
    Boston Area
    If i was to swap the projectors from my OEM HID headlights, would i just use my current bulbs? i am trying to achieve a good cutoff, i am worried that putting HID bulbs in a halogen projector is gonna give me crap visibility. How did yours come out with the H7 HID bulbs? how is the cut off? and brightness? any pics?
    Senior Member Three Rings SilverThing's Avatar
    Dec 26 2007
    cars & stuff
    Long Island, NY
    Charlie,
    Ygpm re: interest in your driver's side housing.
    Rides:
    '06 S4 Avant, silver/black w/ alcantara, w/ V8 goodness - new DD (finally back in an S!)
    '07 A4 Avant 2.0TQ S-line & Ti, I-white/black (unicorn?) - w/ APR goodness, old DD, now beach-mobile
    '93 BMW 850ci, FE Red/Black - major garage queen
    Previous:
    '01.5 S4 Avant, Silver/Onyx (Sold...miss it a whole lot )
    '98 BMW 328ic, Cosmos/Grey/Black (Sold...miss this one a whole lot, too)
    Jun 14 2007
    2000 S4
    Connecticut
    hey man, you should check out the thread a few up. IMPORTVISION.com sells the Depo's 300 dollars. you will need to buy an H7 HID kit with them since its a halogen setup. But they work GREAT! love the ecode pattern its identical to the "real" ones. i would never spend 650 or whatever it is on the headlights when these were 300 and they work amazing.
    Oct 02 2007
    Boston Area
    Red face Re: Aftermarket Headlights
    alright i am reviving my own old thread. the driver's side HID bulb finally went (we have had some serious rain in the last couple days) so i need a solution fast!!! to summarize what you guys told me, my options are as follows:
    1) buy depo headlights (importvision.com, anywhere else????) = $300 + H7 HID kit from ebay - $50, so both = $350
    2) buy an oem replacement driver's side assembly for $450 + $100 or so for HID bulbs ~ $550
    3) buy e-codes for $500 atleast!! + $100 for hid bulbs ~ $600
    Which is it gonna be, i need it done right and ASAP, i'll be doing the work myself, but i am looking for great light output, and nothing ghetto rigged. someone guide me through this??
    Oct 02 2007
    Boston Area
    alright, close this thread, i bought OE replacements from Valeo for 373.95 shipped to my door. It was the easy way out.
    Feb 17 2008
    Ottawa Ont.
    no you didnt. not valeos that cheap.
    Oct 02 2007
    Boston Area
    yes i did, unless they are lieing about the valeo part number
    Veteran Member Four Rings NastyNogaro's Avatar
    Oct 31 2006
    2008 RS4 Exclusive/Premium
    Reviving an old thread.
    What about these?
    http://cgi.ebay.com/ebaymotors/00-02...spagenameZWDVW
    Seem to be decent quality and they are HID's...
    "Made by German FK-Automotive's OEM manufacturer, DEPO, ISO 2001 Certified, Quality is Guaranteed!"
    "Fazz" | Interactive Web & Application Developer | ig: @turbofazz
    2007 911 Turbo 6MT
    2015 Nogaro S4 DSG - Sold
    2008 RS4 Exclusive/Premium - Sold
    2000 Nogaro S4 6MT - Sold
    Feb 17 2008
    Ottawa Ont.
    fk is not depo and depo is not fk.
    nice description there.
    Oct 31 2006
    Quote Originally Posted by BastardS4 View Post
    Knew somethin had to be fishy.
    What is "FK?"
    2007 911 Turbo 6MT
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by NastyNogaro View Post
    What about these?
    We don't drive bimmers....
    Feb 17 2008
    Ottawa Ont.
    What is "FK?"
    The APC of germany.
    I looked at that auction. I dont see any mention of depo on it.
    If you like the look of the the things its a good deal. The FK quality on headlights is like DEPO, not so great in the past, much improved now.
    Oct 31 2006
    I wasn't thinking of getting these so don't attack me gr4hm. I just bought ecodes from a member on here and am sending payment tomorrow morning.
    Just thought I'd add input to a thread about aftermarket headlights. I stayed on topic, no?
    2007 911 Turbo 6MT
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    No worries, I didn't mean anything by it.
    Veteran Member Four Rings sumpsfast's Avatar
    Apr 03 2004
    '92 UrS4 - Black
    Denver/Chi-town
    LOL, but you will spend $300 for knock-offs plus another $200-$300 for an HID kit thats worth a damm [ w/ warranty??], plus installation to achieve the same results? Granted, not everyone is a DIY'er or really cares about the quality of what they are installing until they are scrambling trying to rectify broken or faulty parts.
