Results 1 to 38 of 38
Thread: Best DV/BOV
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    Smile Best DV/BOV
    I currently have mine upgraded to the TT diverter valve. I honestly want more sound, what is a good BOV/DV or Hybrid that works good with our cars, and will work with a BAT setup?
    Thanks
    - Jesse
    Edit: Links would be great, I Want to order soon
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Re: Best DV/BOV
    Depends what sound you are looking for... The sound of BOV or of the Splitter.
    Some people say you can put Forge 007 (DV) in a reverse, and it would be as loud as any BOV... I did that, but got no sound :))) Maybe cause i'm stick stock enginewise. Now i'm running Forge 004 (BOV) and like it.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Mar 12 2008
    Portales, NM
    Re: Best DV/BOV
    Quote Originally Posted by aaaudiprotein View Post
    Where did you buy this, and it works well with our turbos?
    I always here that BOVs dont work well with turboed cars
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    Re: Best DV/BOV
    GFB Stealth FX and Turbosmart Kompact are 2 of the good hybrids, i'm sure you can find sound clips if you search too.
    I've had a blitz dd in the past and that was my fav, but I don't think there is an application for our cars.
    good luck, happy boosting.
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    Re: Best DV/BOV
    I have a Forge 004 BOV for sale. PM me for details. Used for about 5k
    another stereotypical Audi
    Mar 12 2008
    Portales, NM
    Re: Best DV/BOV
    PMed, will 004 work well in my car?
    Senior Member Three Rings Stockton's Avatar
    Mar 04 2008
    2004 A4 Quattro 1.8t 6spd
    Palm Beach Co, FL
    Mar 12 2008
    Portales, NM
    Re: Best DV/BOV
    Thanks, a bit more than I want to spend, bu we will see
    Oct 29 2006
    Vancouver
    Re: Best DV/BOV
    Thats actually one of the least expensive hybrids...
    Another silver B6
    Veteran Member Four Rings jcg05c's Avatar
    Jun 07 2007
    350z
    orlando
    Re: Best DV/BOV
    I need someone to drive my car so i cant hear it go by and how it sounds haha.
    19in Privat Netz 10mm front/17.5mm rear
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Feb 17 2005
    Sarasota, FL
    Re: Best DV/BOV
    Tial 50mm for a BAT
    Mar 04 2008
    Palm Beach Co, FL
    Re: Best DV/BOV
    Quote Originally Posted by jbrown7815 View Post
    How cheap are you.
    Maybe you should get a Corolla.
    Feb 17 2005
    Sarasota, FL
    Re: Best DV/BOV
    Quote Originally Posted by Stockton View Post
    How cheap are you.
    Yea definitely not going BAT if a BOV is too expensive!
    Mar 12 2008
    Portales, NM
    Re: Best DV/BOV
    How cheap are you.
    I'm attempting to save for a FMIC
    Mar 12 2008
    Portales, NM
    Re: Best DV/BOV
    Lmao, yall are harsh. Ok so how is that Forge Hybrid better than just a 004 performance wide?
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: Best DV/BOV
    Here's a link that Old guy found and has a lot of great information.
    Good reading
    http://dv.mistertam.com/5.htm
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Senior Member Two Rings DEMI's Avatar
    Aug 13 2007
    11 S4, 02 A4
    Toronto, Ontario
    Re: Best DV/BOV
    lol, yah they work best on NA engines
    Feb 17 2005
    Sarasota, FL
    Re: Best DV/BOV
    Quote Originally Posted by DEMI View Post
    OWNED! lol
    Oct 29 2006
    Vancouver
    Re: Best DV/BOV
    Another silver B6
    Mar 12 2008
    Portales, NM
    Re: Best DV/BOV
    Quote Originally Posted by A4ringedONE8T View Post
    Tial 50mm for a BAT
    So I'm going to go with this. Since I can keep it with a BAT.
    F you haters
    Feb 17 2005
    Sarasota, FL
    Re: Best DV/BOV
    F you haters
    The Tial flange must be welded on a hard IC pipe, make sure you have a FMIC for that BAT first
    Mar 12 2008
    Portales, NM
    Re: Best DV/BOV
    PM sent
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Re: Best DV/BOV
    From one of the guys out here...
    Yes, Forge 004 is ok with our cars.
    Senior Member Three Rings 11move's Avatar
    Nov 25 2007
    Re: Best DV/BOV
    Go with this its adjustable
    Veteran Member Three Rings 04TurboB6's Avatar
    Feb 17 2008
    Leesburg, Va
    Re: Best DV/BOV
    so what would sound the best with a stock engine?
    Established Member Two Rings j_sonel's Avatar
    Jan 18 2008
    '06 A6 Avant 3.2Q, '06 A4 Avant 2.0TQM
    Chapel Hill, NC
    Re: Best DV/BOV
    The reason it is recommended to use a diverter valve is because it recirculates the air that the maf has already registered and puts it back into the system. A blow off valve will release it to the atmosphere, so the ECU thinks that air is going back into the system, but it's not. The engine and programming are meant to work with a DV.
    If you want sound, remove your airbox and put on a cone filter. Your DV will then become audible and almost as loud as a BOV. IMO, having an audible DV or BOV on stock turbo car is pretty dumb.... Why sound like you have balls under the hood when you can get walked by almost every car on the road?
    Oct 29 2006
    Vancouver
    Re: Best DV/BOV
    Quote Originally Posted by j_sonel View Post
    it's not any dumber than having a great sounding exhaust. I don't think having a bov is to show you have "balls" under the hood. It just sounds great, imo.
    Another silver B6
    Mar 12 2008
    Portales, NM
    Re: Best DV/BOV
    Agreed ^
    Jan 18 2008
    Chapel Hill, NC
    Re: Best DV/BOV
    Quote Originally Posted by BNZ TOY View Post
    To each his own.
    Jun 07 2007
    350z
    orlando
    Re: Best DV/BOV
    haha And i dont think any of our cars really have balls under the hood for except a few, and still even the ones with big balls couldnt beat alot of cars in the same price range. So whats the point in even modding an audi for speed?
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Oct 29 2006
    Vancouver
    Re: Best DV/BOV
    To each his own.
    ...and that is exactly why I didn't say your post is dumb
    Another silver B6
    Jan 18 2008
    Chapel Hill, NC
    Re: Best DV/BOV
    Quote Originally Posted by jcg05c View Post
    Adding power to a car is one thing.... Modding it to make noise is another.
    Jan 18 2008
    Chapel Hill, NC
    Re: Best DV/BOV
    Where did I say anybody's "post" was dumb. I stated an opinion after providing information. The OP obviously doesn't understand too much about BOV's if he thinks they don't work well on turbo'd cars.
    Oct 29 2006
    Vancouver
    Re: Best DV/BOV
    I think the OP was just asking for opinions on good bovs that work with our cars, how can you tell he doesn't know how dv/bovs work?
    I ... I honestly want more sound, what is a good BOV/DV or Hybrid that works good with our cars...
    Jesse
    ... IMO, having an audible DV or BOV on stock turbo car is pretty dumb....
    Another silver B6
    Jan 18 2008
    Chapel Hill, NC
    Re: Best DV/BOV
    That good enough for you???????
    You're just defending the idea of having a BOV because you have one on your car. I'm sorry you don't like my opinion of them.
    Oct 29 2006
    Vancouver
    Re: Best DV/BOV
    Darn, you're right.
    Another silver B6
    Feb 17 2005
    Sarasota, FL
    Re: Best DV/BOV
    I'll gladly take you for a ride and show you the point in building an Audi for power & speed
    Jun 07 2007
    350z
    orlando
    Re: Best DV/BOV
    ^ like i said only a FEW:) and your not considered Balls , your considered NUTS haha. Your car is crazy:) Ill take you up on that if i ever leave orlando and make it down there ahah
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
