Results 1 to 17 of 17
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    Best rods for the bottom end (help)
    I'm planning on slowly building the bottom end. I was thinking of first doing the rods, recommendations or reviews? And yes I've done the searches.
    Pauter Rods
    Scat
    IE
    Any others? Should I replace the pistons and rings at the same time?
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Feb 17 2005
    Sarasota, FL
    Re: Best rods for the bottom end (help)
    If your staying with a 1.8l and happy with 450-500whp at max and 8k rpm, IE drop in rods are more than sufficient. If your going to a larger displacement or want to rev over 8k, you will want/need 20mm pin rods and obviously new pistons. A built head and an appropriate tune is obviously going to go along with the revs as well
    How much mileage on your car now?
    Sep 14 2006
    New York, NY
    Quote Originally Posted by A4ringedONE8T View Post
    I have 74k on her now - originally I was waiting to wear out the engine and do a 2.0 build, but now think I will just rebuild my bottom end of my 1.8 and later the head.
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    Sep 14 2006
    New York, NY
    Shawn - where can you get IE rods and how much do they run?
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    i have 27k, almost 28k miles on my scat rods.
    there was a set of 225tt pistons for sale in the classifieds. cheap. and they have 20mm pins and a slightly lower compression.
    contact via email please.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I would definetly give it some fresh rings
    -Sami-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by k0mpresd View Post
    I believe those are mine. 9.0:1 cr versus the AMB's 9.5:1 Still for sale.
    -Doug
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by GTMRS4 View Post
    You got PM!
    edited for your protection
    Feb 17 2005
    Sarasota, FL
    Good point, edited
    Sep 14 2006
    New York, NY
    I might be interested in the pistons and rods - ping me
    Does anyone know though if I'll need to change my tune since I'm running APR STGIII+?
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I sent you a PM back.
    Lowering the compression ratio will allow you to run more timing advance under boost. I think your APR tune will be okay as is. If you really feel aggressive you could try to add more timing advance and log, log, log.
    [If someone thinks my last statement is incorrect please correct me. I have compiled that from reading and talking to people. No real-world experiences to back up my take on compression ratio.]
    -Doug
    Feb 17 2005
    Sarasota, FL
    Got something for you, send me your email addy when you get a chance!
    Feb 17 2005
    Sarasota, FL
    Yes but your going to get a delayed spool because of the lower compression, the advanced timing it allows you to run only gets back what you previously had. Id rather have the compression!
    Sep 14 2006
    New York, NY
    You've got mail
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    Oct 29 2005
    10speed
    San Francisco, CA
    the best rods are Carillo
    - Clint
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I would avoid using definitive terms such as "best" as it is subjective.
    Some folks think Arrow Rods are the best, others think Pauter Machine makes the best Import Rods, others choose Cunningham.
    The best connecting rod is the one that does not break in YOUR motor.
