Results 1 to 7 of 7
    Apr 09 2008
    Radio wiring harness
    I just dropped in real quick to get some help. Anything is appreciated. My friend owns a 2003 A4 with a symphony II unit. I think its a 2 because all the speakers are amplified. They are all bose. I cannot find the correct harness for this car. I am having a hard time, if I have to order it from europe thats not a problem I just need to pointed in the right direction. On the stock harness for the radio there is one block of plugs for just speakers, the other block is just power connections and illumination and so forth.
    Thanks in advance
    Senior Member Two Rings Eyerate's Avatar
    Aug 19 2007
    Re: Radio wiring harness
    wat
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Apr 09 2008
    Yeah that one definitely doesn't work, I went and picked that one up at a audio shop in Jersey and it doest fit...I don't know what the deal is.
    Feb 07 2008
    Orlando, FL
    either you didn't get the same one or your doing something wrong, b.c it definitely does work! I have an 03 A4 that originally had a symphony II in it as well, and that harness works perfectly with my Kenwood DDX-7017.
    Oh, I did have to run a power constant, but that was it.
    15 S6 4.0T Quattro
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    also works for my AVIC-D3
    Quote Originally Posted by Dirty View Post
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    Oct 27 2007
    and check this for any stereo info you might need
    http://www.audizine.com/forum/showthread.php?t=163304
