Results 1 to 21 of 21
    Veteran Member Three Rings nealRlett's Avatar
    Nov 27 2007
    B7 S4, '71 BMW R75/5
    Best Leather Cleaner Ever !!!!!
    Just wanted to share my recent leather cleaning experience with the Leather Masters System.(Thanks to Grouse out in Seattle)
    I recently just cleaned and conditioned the RECARO leather in my 06 S4. I used the Leather Masters System which came out incredible! No greasy feel at ALL and no horrible smell, just really soft leather. There is no visible difference at all. It looks like the leather the day I bought it, only softer.
    Here is what I did:
    If the leather is standard it is a protected leather. With that I would recommend either moe's method or the leather masters system. If it is an upgraded leather. it very well may be aniline dyed, meaning there is no protective coating. Because of that I STRONGLY recommend sticking with the leather masters system.
    Strong cleaner. (dilute 1:3 cleaner/distilled water)<that dilution makes soft cleaner>
    Leather vital
    Leather protection cream.
    The procedure is to vacuum the seats, remove all loose debris, pick off all dried matter as best you can.
    apply the strong cleaner to the sponge of boars hair furniture brush.
    Work/agitate into a lather.
    Apply cleaner to a 18"x18" area, agitate and or brush in slightly. This is not a scrubbing action but simply to ensure the cleaner is all over the leather.
    Let sit for 20-30 seconds.
    Wipe off excess with clean microfiber.
    Repeat process on next 18"x18" area.
    After all leather is done you will want to wait till the leather is fully dried. This is important. Leather is damaged by excess moisture, it dries out rapidly. think of a wet pair of leather gloves (ala oj) they dry out, shrink and become brittle. Leather masters is a low moisture method of cleaning. Specifically designed to work with aniline dyed and protected leathers.
    After the leather is dry, Depending on where you live, temp, humidity 20 min - 1 hour. Assess if it needs to be cleaned again. I generally clean it two times for good measure.
    Wait for it to dry again, Often i will use a air mover or a blow dryer on low warm air held 2 feet or more away from the leather.
    After leather is dry, you can generally move onto Leather vital. This is the main conditioner. For a 4 door extended leather (doors, dash, seat fronts and backs) vehicle you might use 1 oz on two applications of vital. A normal car would be 1/4 oz or so, protected leather even less.
    Again you want to wait till it is fully dry. 20 min to 1 hour. This is to ensure it will soak in to the leather and not just goop up on you.
    After that i usually do a second leather vital application using 1/3rd the amount i did on the first time. both applications are very very thin layers. Just like wax, less is more.
    Wait for it to dry.
    Apply leather protection cream. This has uv inhibitors that keep the leather from drying out from to much sun lite. this will generally be 1/2 the amount you used on yoru 2nd coat of leather vital. If there is any excess after 5 min, wipe off with clean micro fiber.
    I hope this helps,
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 24 2004
    Re: Best Leather Cleaner Ever !!!!!
    wow great write up Aaron is an interior guru!!!!!
    Nov 27 2007
    Yes he is. I am glad I did not use anything other product. The seats came out exactly how I wanted them.
    Veteran Member Four Rings Grouse's Avatar
    Sep 06 2005
    05 a4 3.0 Ultrasport
    Norwalk CT
    How did i recomend this to you :)? The last 20 days or so are a haze for me.
    USPClub Member # 32
    Nominated best detailer in western washington
    Chosen as one of the top 9 detailers in the US by autoweek.
    Nov 27 2007
    Quote Originally Posted by Grouse View Post
    It was a while back. Here is the thread:
    http://www.audizine.com/forum/showth...=nappa+leather
    Just wanted to say thanks for the great product recommendation.
    Senior Member Three Rings snowbird's Avatar
    Nov 20 2007
    '04 S4, '11 Q5, '90 Corrado, '96 911 C4S
    Toronto ON
    got any pics of the finished product?
    Nov 27 2007
    Quote Originally Posted by snowbird View Post
    I don't, sorry. I can take some pics if you want, but it basically looks the same as it did from the factory. That is why I love this product so much. There is not one sign of grease at ALL!! It's factory perfect, and highly recommended!
    Active Member One Ring vegascoop's Avatar
    Jul 02 2008
    Las Vegas
    Great write up. One question, what's a "sponge of boars hair furniture brush"
    May 29 2008
    is "recaro" leather different than other audi leather?
    i have an 05 S4 cab. the leather is gray and of course being a cab it gets dirty fast when the top is down.
    i started wiping it with leather condidioner but tha didn't really take the dirt out, just made it shiny dirty.
    is this "leather masters system" something i can get at an auto supply store or does it need to be ordered online?
    Feb 24 2004
    May 31 2007
    Montreal
    I got my order from Phil.
    I have leatherette in my car but I have a client with an M3 who wanted to have his seats treated with the best product out there.
    Cleaned my front seats.. I used the Adams foam pads. Man that thing cleaned the seats so perfectly and gave them a nice natural gloss. I then put the vital, and it's sitting there. Tomorrow I'll be adding the protection cream.
    This is 10x more efficient than any leather care product I've tried so far.
    Jul 02 2008
    Las Vegas
    Can you use the "Swissvax Leather Brush" I see on the Detailer's Domain to apply Leather Masters?
    I don't see any sponges listed under the Interior Section of the website.
    Feb 24 2004
    you can use that or you can use this:
    http://www.detailersdomain.com/index...PROD&ProdID=74
    Sep 05 2008
    California
    How about for water protection? My S4 will be making snow trips and I would like to protect the seats from any water damage.
    Established Member Two Rings mefischer77's Avatar
    May 10 2008
    2005 Allroad 2.7t Stealth
    Breckenridge, CO
    So I like my leather pretty stiff, like right from the factory, and worried that too many "conditioners" will make it too soft, and eventually need a face-lift stretch. What can I use to clean, protect, and condition the leather, without making too soft?
    May 10 2008
    Breckenridge, CO
    Quote Originally Posted by phil@detailersdomain View Post
    Phil, in a previous thread you were recommending the Einszett Lederpfledge, so do you think the Leather Master is a better choice for a dull finish, stiffer look/feel?
    Feb 24 2004
    Einszett would be great for a newer interior.
    LM is great for both. Also its a 2 or 3 step.
    LM has a greater ability to restore the leather and refresh it, (it won't make it new or get rid of cracks it will keep them soft /conditioned/matte)
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Is this stuff supposed to remove "dry" spots in leather?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Feb 24 2004
    within reason it will get the leather to look pretty good and it will replenish the look and life of the leather do you have pictures of what you will be working on
    Jun 04 2007
    Austin/DFW, TX
    Its pretty bad, and the leather itself is pretty hard too.
    dry spot
    gives you an idea on the condition of the leather.
    Any specific extra instructions for this damage with the LM kit?
    My 5-Speed Swap DIY
    - B6 USP
