Results 1 to 12 of 12
    Senior Member Two Rings Betty1.8T's Avatar
    Feb 12 2008
    2001 Audi 1.8T
    San Jose, Ca
    Does Anyone know how to remove an Cigarette light/ electrical socket??
    I have a 2001 Audi A4. I've been wanting to replace the socket for a while. I haven't figured what I really need to remove. I have searching online for some DIY help, but no luck.
    Sep 13 2007
    Re: Does Anyone know how to remove an Cigarette light/ electrical socket??
    If its anything like the my 99 the whole ashtray Assembly pulls out and the back of the socket should unscrew and you just pull it out.
    Feb 12 2008
    2001 Audi 1.8T
    San Jose, Ca
    does your 99 have the socket where you just push down and it rotates up?? i already removed some screws behind the hand rest.
    Sep 13 2007
    thats what mine looks like
    Feb 12 2008
    2001 Audi 1.8T
    San Jose, Ca
    nope...My cigarette lighter is right by my hand break. and it swivels up. so in yours it's next to your ash tray. The 01' has it's lighter in the mid-center console. right of the hand break. Thanks though.
    Feb 12 2008
    2001 Audi 1.8T
    San Jose, Ca
    Its the top far left box. It looks like I might have to replace the whole thing instead.
    Sep 11 2007
    Dirty Jersey
    is it broken or just not working?
    have you checked your fuses?
    if you have to take it out loks like you'll need to remove the whole center console, start by taking the arm rest off
    Q7, Q7, F-type manual
    removing the center console is really easy. 5 minute job. pop out the rear ash tray and remove the two bolts, remove the two screws up front attaching it to the front part of the center console, remove the handbrake cover by undoing the screw/catch at the base of the handle (not the lever itself). there may be a bolt under the cupholders under the armrest, but i dont remember off hand. dont forget the electrical connector underneath though. disconnect it before moving the console too far.
    Feb 12 2008
    2001 Audi 1.8T
    San Jose, Ca
    Do you guys know what number fuse i might need to check hopefully replace for the cigarette lighter? Another question, is the fuse box I check is by the drivers side??
    Veteran Member Four Rings gmx's Avatar
    Mar 01 2008
    '12 1M
    Sydney, AU
    Quote Originally Posted by audispeed View Post
    Can't see this, anyone care to elaborate.
    Fucking stuck at this part...
    Quote Originally Posted by gmx View Post
    look at the handle part, not the whole lever. it is underneath where the part you grab meets the rest of the lever. you could just force it off and break the screw, but i wouldnt recomend that.
    Mar 01 2008
    '12 1M
    Sydney, AU
    thx, found the hook.
