Results 1 to 23 of 23
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    How to mount the s-line roofspoiler on the non s-line Avant???
    Anyone done this?
    Regards
    Eirik
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Nov 24 2007
    Tromsoe, Norway
    Re: How to mount the s-line roofspoiler on the non s-line Avant???
    No one?
    Jun 02 2007
    2004 cbr600 rr 1988 16V scirocco
    vancouver
    probably because we don't get roof spoilers with our s-line package so no one knows they exist. Do you have a pic?
    Nov 24 2007
    Tromsoe, Norway
    What?? You don't?
    The partnumber is 8E9 827 933 C GRU
    Small picture but you can see the spoiler.
    E
    Nov 05 2007
    Oregon
    I've done it.
    It's simply placed over the stock spoiler and bonded down. Let the car sit 12 hours or so. The stock spoiler serves as a support for it. Test fit it, but that's how my install went (done by dealer).
    Nov 24 2007
    Tromsoe, Norway
    Ok. SOunds good. But I guess you have to cut the mounts under the s-line spoiler for it to fit over the old one, Right?
    E
    Veteran Member Three Rings dubless's Avatar
    Apr 15 2005
    Carlsbad, CA
    Did this to mine. No cutting or anything. Just clean/de-wax the top of the stock spoiler. Run a few beads of the adhesive lengthwise across the area and around the perimeter. Then press the sline spoiler on. Use masking tape to hold it in place and a couple of well placed books to add pressure. Let sit overnight and your done
    One tip, the audi adhesive given with the spoiler has a very short shelf life. More than likely it'll be fully cured by the time you get it and'll be useless. Go to a place that sells windshields/auto glass and ask for a tube of polyeurethane adhesive (usually made by 3M). Make sure the tube is still soft as well. The first tube I bought was also fully cured and I had to buy another one. Good luck!
    DTM....FTW!!!!
    Nov 24 2007
    Tromsoe, Norway
    Nice, but it looks like I have to cut the innermountings on the s-line spoiler? It is 2 screwmounts that comes down inside the spoiler. Did you have this?
    E
    Senior Member Three Rings Allan T's Avatar
    Sep 28 2006
    Audi a4 b7 2.0 Tfsi quattro avant sline
    Sweden
    Quote Originally Posted by redlabel81 View Post
    E
    Hey E
    I have found a text and a picture on how to mount the spoiler, so send me your e-mail and i will send it to you.
    Allan T
    Nov 05 2007
    Oregon
    our car did not have the "inner mountings"
    you might want to check and make sure this is the right spoiler for your car before you go to install it and find it's the wrong one! I got our spoiler from ECS tuning and there was nothing to trim, it just glued over the old one. Perhaps if it's a different part number, that could be true, that it's just a one piece spoiler that completely replaces the smaller stock spoiler. Or, if possible, go look at an S-line avant and see if it looks like the piece is covering the smaller stock spoiler.
    Nov 24 2007
    Tromsoe, Norway
    Re: our car did not have the "inner mountings"
    Quote Originally Posted by artinmoTTion View Post
    Hi!
    It should be the correct spoiler! Think you only have one partnumber for the s-line roofspoiler. When I look at other s-line avants you can see that the s-line one cover the non-sline spoiler.
    E
    Sep 28 2006
    Sweden
    Hey E
    Here is another picture of it.
    Nov 24 2007
    Tromsoe, Norway
    Decided not to drill holls in the original spoiler so I just cut off the inner mounting. Will clue it with Tec7. What kind of tape should I use to hold it in place? Has to be kind of strong to keep the spoiler in place while the tec7 dries.
    E
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    I think you're talking about two different spoilers. The one shown in ETKA print out is the standard spoiler (8E9 827 933 C GRU). The one artinmoTTion got from ECS is likely the Votex one (8ED 071 640 9AX).
    Sep 28 2006
    Sweden
    E
    Hi E
    Do you have so pictures you could upload of the back of the spoiler?
    Allan T
    Nov 24 2007
    Tromsoe, Norway
    Hmmm.....Back of the spoiler? Do you mean under\the inside of the spoiler?
    It's 2 bolts that you have to cut of if you don't want to drill two holes in your original spoiler. The s-line goes on top of the non-sline spoiler.
    I have cut the two bolts of now and it is ready for mounting but it is just to cold outside to do it and I don't have a garage. :(
    So any recommendations regarding tape to hold it in place while drying?
    Sep 28 2006
    Sweden
    Yes, the inside of the spoiler
    Hao about ducktape (gaffatape)
    Allan T
    Nov 24 2007
    Tromsoe, Norway
    I am not sure if the ducktape will harm the paint....?
    Nov 24 2007
    Tromsoe, Norway
    Anyone with any view on this? What kind of tape have you guys used to hold your mods in place while the glue dries?
    E
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    painters tape, it will come off with out leaving a mark. no duct tape
    Nov 24 2007
    Tromsoe, Norway
    Nice! Thanks :)
    Senior Member Two Rings toro's Avatar
    Mar 05 2006
    09 A4 Avant
    Bayarea, CA
    Quote Originally Posted by Allan T View Post
    Hey E
    Allan T
    Hi Allan,
    I am trying to install my Avant spoiler too, could you please send me the text and picture to me too. I will PM you my email. Thanks a lot
    Travis
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    it will...
    You could also use a but of 3m double sided emblem tape (large width) but thats risky if you drive at high rates of speed..
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
