Results 1 to 23 of 23
    Established Member Two Rings Altec-Racing's Avatar
    Aug 31 2007
    04 USP blk/blk
    *** APR SNUB MOUNT = Rough IDLE
    I installed the (red) apr snub mount last night, and now my idle is shit. feels like my car has been transformed a giant black vibrator!
    well, anyways... on recomendation from achtuning I soaked the mount in wd-40 before installing it on the snub bracket and bolting it in. where did i go wrong?
    Cheers..
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Re: *** APR SNUB MOUNT = Rough IDLE
    Did you loosen everything to hand tight and idle the engine for a minute or to without reving BEFORE you tightened it all back down?
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    nothing is wrong sir ... its doin its job. I had a Honda Civic .. pretty crazy car .. had Arizona Racing Motor Mounts ... Same concept as the APR snub mount.... So it didnt bother me because I knew what to expect. The best thing is that the snub mount is NO WHERE near as bad as full motor mounts, so ... yeah. ... get used to it or take it off ... thats what performance parts do ...
    Not trying to be a prick btw... just common sense
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    it should break in within a week. i noticed rough idle on my a4 when i first installed the snub...but then it wore in an never noticed it again. it wasn't completely horrible or anything but it was noticeable and enough to bother me....but it went away.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Feb 28 2006
    Pittsburgh-Philly
    With all due respect, there shouldn't be anything different in idle from a snub on our cars if it was installed correctly.
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Never had a problem with my APR Red.
    Aug 31 2007
    04 USP blk/blk
    Quote Originally Posted by rxrep View Post
    I'll try that thanks! btw, once i get into the rev's the car smooths out completely. i might have a bad maf situation going on which is exaspirated by the new snubber.
    -Jon
    Aug 31 2007
    04 USP blk/blk
    Quote Originally Posted by b00st View Post
    exactly... its more a massage than anything. my girlfriend loves it
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Read post #6 in this thread: Clicky click
    Aug 31 2007
    04 USP blk/blk
    how about throwing the car up on 4 jack stands instead. lot more work, but using ramps annoys me.
    Aug 31 2007
    04 USP blk/blk
    Quote Originally Posted by VZWalex View Post
    i would hope that our mid level german luxo cars idle a bit smoother than a honda civic rice burner. but i get what you're saying though.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    i hate my apr snub after 10k miles it cracked
    but vidration wise...nope....do what rxrep said
    -Sami-
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    like i said...give it a week and see whats up. i had my apr installed by al from CPT and i noticed the vibrations as soon as i got in...i also noticed it cleaned up my DT slop. about a week after driving...i never had any vibrations. mine never cracked/ripped/broke or any of the above. if its still doing it...swap to ecs snub.
    The RIDES:
    AMA Member
    JHMFTW!!
    Registered Member Two Rings ComfortRacing's Avatar
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    listen to OLDGUY too, his solution worked for me. i of course made the mistake of tightening it all first..
    2002 A4 Quattro 5-speed, KO4, SPP Ported/Polished Turbo Manifold, ATP test pipe, APR ko4 tuning, APR injectors, APR R1 DV, Front mount intercooler, H&R sport springs/Bilstein sport shocks, Neuspeed snubber mount K&N, Blackedout grille, Badgeless rear.
    To Do's:
    -APR Sport exhaust
    -Porsche seats, brakes and wheels
    -Recarro Baby seat =)
    Aug 26 2005
    2nd ^^, If vibration at fully warmed up idle in neutral increased, the snub is not centered in the pocket bracket. The snub must not touch the bracket with engine idling in neutral gear. (Or, for Tip trans, in "D"rive and "R"everse.)
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    JUST AN FYI, i did loosen the mount, ran the car at idle and then tightened and it took away most of the idle roughness, but it wasnt till i had my car worked on taoday at NGP racing did the rougness go away. somewhere between the new R1 dv, apr software and the new green top temp sensor the roughness is completely gone! so it may not be all the snubs fault.
    just my 2 lincolns.
    To Do's:
    -APR Sport exhaust
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I took my snub and machined(ground) about 1mm off each side so it would slide into the cup and barely touch the top and bottom. After I installed it I just let the cup rest on the top of it and tightened it.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    my apr snub has been on for 10k and its been strong. i've also got it used so it probably has about 20k to it.
    no extra vibrations, but shifting is smoother. during intall, make sure you loosen "cup" it goes on, and turn on the car to let the mount settle itself.... make minute adjustments to get it centered as much as you can and tighten the bolts. enjoy!
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Active Member Two Rings elsuntao's Avatar
    Aug 04 2009
    B7 a4 2.0t Audi AR 2004
    indeed there is a rough idle but ive been having a "weird" idle sound after chipping it. Changed the dv and camshaft and it still there. Id appreciate some feedback
    Mar 17 2008
    Snub mount cannot touch the bracket its sitting in. It has to be completely centered. If its touching the bracket it will pass vibration to the frame of the car.
    Dec 30 2010
    Minnesota
    My APR Snub has been perfect since install. No vibrations of any sort, good product but you get used to it fast.
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Quote Originally Posted by dirtybrd View Post
    ^same
    took a little of the bottom of mine to get rid of a little vibration i was getting in the wheel
    Please Drive Right
    Dec 03 2008
    Orlando, FL
    my APR snub is fine as well. no vibrations. I read the post old guy is referring to and made the adjustments and now I have 10,000 miles on it and no cracks.
    2004 A4 1.8T USP
    K&N filter, APR snub mount, RS4 rear sway, APR TIP, custom cat delete pipe (waiting for tune after Holidays)
    Soon to come: Eibach springs with ???
