Results 1 to 3 of 3
    Active Member Two Rings seannb78's Avatar
    Sep 18 2007
    2013 Audi TT RS, 2013 Mercedes GLK350
    Land O Lakes, FL
    Question about my new brakes.
    I am replacing my brake pads with PBR creamics and ECS cross drilled and slotted rotors this weekend. My question is, if any of you have done brakes on your B7, did you also have the brakes bled, or is it necessary. My car only has 27k miles on it, but I wanted to get a good idea from anyone who may know. Thanks
    Mar 27 2005
    The Cold North
    Re: Question about my new brakes.
    bleeding the brakes is pretty quick and easy and should be done every so often as a maintance thing. I usually bleed them 1x/yr or after a track day where i may have been a little over aggressive with the brakes. Bleeding the brakes every 30k miles would good maintance.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Quote Originally Posted by EBG 18T View Post
    Correct--you should flush/bleed your brake fluid every 2yrs or 30k on average. Of course if you drive aggressively (ie track/DE days), doing it sooner is good too.
    I hope your rotors last a good amount of time.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
