Results 1 to 12 of 12
    Active Member Two Rings seannb78's Avatar
    Sep 18 2007
    2013 Audi TT RS, 2013 Mercedes GLK350
    Land O Lakes, FL
    Question about brakes.
    I am replacing my brake pads with PBR creamics and ECS cross drilled and slotted rotors this weekend. My question is, if any of you have done brakes on your B7, did you also have the brakes bled, or is it necessary. My car only has 27k miles on it, but I wanted to get a good idea from anyone who may know. Thanks.
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Re: Question about brakes.
    You may be able to cheat and not bleed- new pads just push fluid back up into the resevior- the system stays sealed. Still if you've driven hard and gotten the brakes to fade or glaze, it's better to bleed and have fresh fluid.
    "Obsessed" is a word that the lazy use to describe the committed.
    Registered Member Four Rings 4-tified's Avatar
    Sep 18 2006
    A4 2.0T Quattro
    Chicago
    Quote Originally Posted by audimeister View Post
    I agree. If you're going to all the effort to replace those parts, then do the WHOLE job correctly and have new fluid put in and the system bled.
    It's really easy to do, so why not just do it.
    Veteran Member Four Rings John1.8T's Avatar
    Jun 08 2005
    2005.5 Brilliant Black Audi A4 2.0T Quattro 6spd.
    Waterloo, Iowa
    Quote Originally Posted by 4-tified View Post
    Agreed.
    Since your going with new pads and rotors, you might as well flush the system and put some better brake fluid in as well. I've had good luck with DOT 4 ATE Super Blue Racing fluid.
    Sep 18 2007
    Land O Lakes, FL
    Thanks for all the posts. I will get the brakes bled as well.
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Agreed. You don't have to bleed the lines at all though. If you don't own a piston compressor tool, I would recommend renting one from AutoZone or something, since I think it's the fronts that you have to twist the piston as you push it back into the caliper.
    Brakes are brakes, they're all the same. Make sure you don't strip the guide pins
    Ignorance is bliss.
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    yeah do it right. I switched to the Neuspeed SS Brake lines and Motul brake fluid. Stops on a dime and Pedal feel is great !
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Veteran Member Three Rings quattro.it's Avatar
    Mar 24 2008
    2004 BMW R1150RT
    Bellevue, WA
    Quote Originally Posted by John1.8T View Post
    Agreed.
    Yep, like they all said.
    2007 A4 2.0T quattro Tip S-Line Titanium / Lava Gray / APR 91 /
    Veteran Member Four Rings viperdsa's Avatar
    Aug 28 2007
    Angry Gerbils
    west of the equator
    keep us posted on how you like the new setup. I'm thinking of doing the same thing but with SS lines also.
    '06 Dolphin Gray A4 2.0T
    Motoza Tuned EFR
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Yes, you'd have to re-bleed the entire system. Last thing you want would be stomp on your brake pedal as hard as you can just to not rear-end the guy in front of you...and still hit him.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Jan 24 2007
    Wisconsin
    I'm not going to lie... I had PBR ceramic pads on my first VW for a while. They grabbed great, pad life was mediocre, and they were dusty as hell. They stop good though
    Ignorance is bliss.
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    It's the rears that require the piston retractor tool and if you're under warranty, why not have the dealer flush and bleed your brakes. They're supposed to do that service at least once during the 50k.
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
