    Veteran Member Four Rings Fobia's Avatar
    Oct 04 2005
    Minnesota
    how to take rolling shots with rebel
    like the title says.. ive experimented very briefly trying to get the rolling shots but the shutter speed always seems to fast.. but it needs to be fast to get the right exposer....?
    so i assume you get the car rolling at 55 mph then focus the above the wheels..
    anyone have any recommendations as far as modes shutter speeds aperture size to be in with my cannon rebel xt with a standard EFS 18-55mm lens.
    thanks chris
    2010 ibis white s4
    CTS Turbo intake
    Veteran Member Four Rings Rhynolite's Avatar
    Sep 12 2007
    A
    Re: how to take rolling shots with rebel
    When shooting rolling shots with my Rebel XTi, I usually go with a 1/40 or 1/30 shutter speed and focus right above the wheels like you said.
    Result:
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    tighter aperture and longer exposure. slower than 1/30 and you are likely to be 'fuzzy' because of vibration.
    try slower film speed too. no real cut and dry answer as it all depends on lighting.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Quote Originally Posted by Fobia View Post
    thanks chris
    there is absolutely no reason to go so fast, you can get great shot's at 10-15 mph, you can experiment by metering to car with the auto setting and then slowing down the shutter in Shutter priority by 2-3 stops, you may want use a mono pod or tripod to steady the camera. There will be some trial and error involved.
    In the pic above I think part of the problems is the sun causing a reflection and it takes away for the pic.
    My opinion.
    Oct 04 2005
    Minnesota
    used the door card. went back and forth between shutter speeds.. i didnt know how to select focus points on the camera so that might help next time.
    resault in TV mode and AF on...
    i dont know how to mess with the aperture when in TV mode
    2010 ibis white s4
    CTS Turbo intake
