Results 1 to 13 of 13
    Feb 18 2008
    Getting my car this weekend! noob questions...
    2003 1.8t A4 77,414 mileage....
    What are something maintenance things I should do off the bat to prevent any bad things from happening....
    1. I will be doing the Timing belt very soon, I have a volvo mechanic to give me a hand so I think this will go pretty smooth... ( I will be using the Audizine how-to) Any have good luck with that guide?
    2. Whats the best way to detect engine sludge... I read about a lot of issues people are having on here... it scares me!
    Any other tips?
    Thanks in advance...
    Veteran Member Four Rings B7A4WD's Avatar
    Jan 27 2008
    B7 A4 2.0T Q S-Line
    New Port/ Fullerton
    Re: Getting my car this weekend! noob questions...
    nice!
    Feb 18 2008
    Yeah I'm excited... I'm hoping to catch some stuff early, so hopefully some people post some help for me.
    Veteran Member Three Rings 04TurboB6's Avatar
    Feb 17 2008
    Leesburg, Va
    seafoam your car for sludge issues...i did it when I bought mine two months ago..
    Veteran Member Three Rings 02B6's Avatar
    Nov 05 2007
    Toronto, Canada
    usual maintenance. timing belt, spark plugs, coilpacks, oil change, fuel filter. amosg some of the things you can do to prevent any future mis-haps. As for sludge do a search on "seafoam"
    2002 (B6) 1.8TQM...H&R - S4 Spoiler - 6k HID - open cone filter - Forge Splitter - avic d3 - podi/SW
    Veteran Member Four Rings deephouse's Avatar
    Sep 18 2006
    Your Mom's house
    Quote Originally Posted by FrostofSparta View Post
    Any other tips?
    - check the brake pads. I bought my car at 36,000 and it now has 71,000 and i still have not changed the brakes but it brakes fine. You should be weary of how thin your pads are.
    - 03 had a fuel pump recall, typical symptom is a buzzing or humming coming from rear passenger side wheel well.
    - proper flush and refill of coolant.
    - if i could recommend 2 "NON-PERFORMANCE" mods for any noob it would be in th safety and comfort department:
    1. euro blind spot mirrors (they are AWESOME)
    2. Audi All Weather sport mats
    Feb 18 2008
    Awesome! thanks for the tips... I'm totally worried about sludge of course because of all the horror stories I read on here and the fact I'm not sure how the car was treated before I bought it.
    I'll definatly do the seafoam trick. Is there a how-to on the can or is it pretty easy to find something around the interweb? I've also see people putting in the gas tank... Do you suggest this as well?
    Thanks!!!
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Look inside the fill oil fill cap with a flashlight
    -Kris
    Feb 18 2008
    Registered Member Three Rings
    May 27 2007
    04 1.8T USP || 09 Camry SE
    Melbourne, FL
    It'll look like this...not good. Click on the picture for a larger view.
    || APR Stage 1+ || ECODE FMIC || Thermal R&D Exhaust with Milltek DP ||
    || Stewart Warner on PODI || TT225 || Eibach CO || 710n ||
    USP CLUB MEMBER #737
    Feb 18 2008
    haha I'll keep that in mind. You guys have good success with seafoam?
    Veteran Member Three Rings Noodle's Avatar
    Oct 16 2007
    Pittsburgh, PA
    The only reason, due to my knowledge, that sludge occurs is because of two things. 1) Not using a recommended synthetic oil, and 2) not changing it regularly. If you do both of those things, you'll be f'd with a 10ft pole.
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    Use Auto-RX. My mechanic says hes never seen a 1.8T that was cleaner!! (with 67kmiles)
    another stereotypical Audi
