Results 1 to 9 of 9
Thread: Tip on Dyno
    Senior Member Three Rings JoeM's Avatar
    Nov 01 2007
    Vancouver, Wa
    Tip on Dyno
    You guys have any tricks to keep the Tip from shifting on a dyno. The longest we could get it to hold out was 6300 RPM.
    Also, anyone make a chip for the TCU in these cars?
    -Joe-
    '08 A4 2.0T Q
    '01 Land Rover Disco II
    '99 Porsche Boxster
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    Re: Tip on Dyno
    yeah keep it in Smode. Mine does not shift until 6800-6900 RPM. What kind of # were you getting
    Oct 11 2007
    Suburbia
    Re: Tip on Dyno
    agreed S mode, or try an actual gear in the tip mode.......
    Registered Member Two Rings scabdc's Avatar
    Feb 05 2008
    06 A6 4.2 06 E55 AMG
    MD
    Re: Tip on Dyno
    Quote Originally Posted by JoeM View Post
    No chip for the TCU AFAIK (and I did look into it.)
    Senior Member Three Rings va-terps4's Avatar
    Feb 11 2007
    NoVA
    Re: Tip on Dyno
    Quote Originally Posted by scabdc View Post
    I talked to a GIAC rep about their tip chip this past weekend. They don't have one for the B7 yet because they want to do it thru the flash loader. At least it sounds like they are working on it.
    2016 SQ5 Prestige - Glacier White/Black Milano/Carbon Atlas
    2013 Q7 S-Line ... 2008 S6 Sedan ... 2007 S4 Avant ... 2002 allroad
    Nov 01 2007
    Vancouver, Wa
    Re: Tip on Dyno
    I mentioned keeping it in S and using the paddles to shift up to 3rd gear, they said they were but it still was shifting at 6300rpm.
    I was getting abour 275hp and 270tq at the wheels, with no signs of HP dropping off. I figured if it would have hel I would have hit 290-300 at the wheels.
    Va-terps4: I have a B6 but I dont think that matters about a tip chip does it?
    -Joe-
    '08 A4 2.0T Q
    '99 Porsche Boxster
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Re: Tip on Dyno
    umm... i dunno usually S mode will keep the revs up to 6900, which works out since the tip peaks (supposedly) at 6800 rpm instead of 7000 like the manual
    Mar 27 2006
    Re: Tip on Dyno
    mybe the b6 is different from the b7 Tip. who knows.
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    2022 Mazda CX-5, 2013 HD FatBoy Lo
    Virginia
    Re: Tip on Dyno
    what performance mods do you have?
    EDIT: never mind, read your sig
    -Cliff
    Current:
    B9.5 //S4-Prstg-Turbo Blue on Gray-30% Tint
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
