Results 1 to 7 of 7
Thread: Turbo ?
    Registered Member Two Rings //EsFour's Avatar
    Feb 21 2008
    Chicago
    Turbo ?
    So I've been researching a lot on audiworld and here on audizine, and it looks to me like the majority of people look to K04's as a turbo upgrade. Why?
    Garrett GT turbos seem insurmountably better than "stock" upgrades. Is this a fitment issue? A space issue? IMO, I would never upgrade to K04's if I could find a better turbo to use.
    Can anyone enlighten me?
    Senior Member One Ring
    Oct 17 2006
    philly
    Re: Turbo ?
    ko4's bolt right up to stock everything except for inlets
    thats why everyone uses them
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: Turbo ?
    k04's are the standard stage III. GT turbos require a lot lot lot lot of bank. special manifolds, inlet pipes, hardware, tuning, the list goes on. look up everything on ASP's website, its like 15 grand for a properly tuned setup on there (although custom can probably be cheaper), GenerationJDM is doing his own i believe, and so is GURUMAN.
    Hey if we could do it we would, but most of us are content with k04s.
    the middle ground are the RS6 turbos (another "stock" upgrade), but they are proven to put out big numbers, although i believe these require new manifolds also.
    k04s while theyare a "stock" upgrade, are miles upon miles more reliable than our stock k03s.
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Feb 21 2008
    Chicago
    Re: Turbo ?
    Quote Originally Posted by jungb5s4 View Post
    Seems like I've got a lot more to learn. Thanks for the info :)
    Jul 07 2007
    Tempe, AZ
    Re: Turbo ?
    just pm those two, they have all the GT knowledge you'll ever need
    Veteran Member Three Rings ss4's Avatar
    Jun 04 2005
    San Diego
    Re: Turbo ?
    The RS6 turbos use the factory S4 manifolds and the oil/water lines; the downpipe flanges do need to be modified.
    Feb 21 2008
    Chicago
    Re: Turbo ?
    Quote Originally Posted by ss4 View Post
    So what does everybody do for downpipes/manifolds around here? Let's say I would keep things fairly straightforward and decide to go with RS6 turbo's. Research shows that JHM has started or is in the process of making a bolt on kit, but what about manifolds? Downpipes?
    The exhaust I would most likely have fabricated almost to a T like this, but replace the 2.5 inch piping with a full 3" design all the way through:
    http://www.youtube.com/watch?v=LqEqXckkBKA
    ___________________
    RULES FOR PASSENGER:
    1. No screaming or crying.
    2. No touching buttons or levers.
    3. Hold on.
