Results 1 to 6 of 6
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    would you cut cat back?
    I'm actually going stage3. Each d/pipes ares 2.250'' entering my cat back. My cat back will become one 3 3/8'' at the midle but then entering in a high flow muffler with two 2'' exits. WTF i'm intering 2,1/4'' and exiting 2''. Would you guys cut mufler and weld a straight 3,3/8'' pipe till the end of car? Or cut out the tips at the end of muffler for bigger ones?
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: would you cut cat back?
    Cutting the tips of the muffler won't due much good. What brand exhaust is this.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Oct 14 2007
    Val-Belair
    It's a neuspeed. I'm not saying just cutting the tips, but also bore the holes and weld some biger tiips.
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    wouldnt it be est to not have any mufflers at all and just have straight pipes
    thats the most freeflowing way
    of coarse thats going to be rediculously loud but if you dont care i think that would be the way to go
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Jul 06 2007
    San Jose, CA
    I say 3 3/8" all the way back then.
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Get a 3" in and 3" out straight flow muffler in the middle. Don't bottle neck the exhaust with a small muffler, it defeats the purpose of a bigger exhaust.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
