First of all, I'd like to start off by saying....ajdflksjdflkasjdflkajdflkjdf!!! F@CKKK!!!!
Now....onto the problem....
So, I came home from college yesterday because I had a dentist appointment, and before I even pick up the keys, my dad tells me that "The rear suspension sounds loose." Of course, I tell him thats impossible, cuz I tightened EVERYthing to factory specs when I installed my KW Variant 3 coilovers last year, but I told him it could've been a blow shock, which I also doubted.....So I took the car out for a drive, and everything was as smooth as usual....BUT, on small bumps, i'd hear a loud banging sound coming from the rear passenger side wheel well...
So, after a lil test drive, I got out my torque wrench, re-tightened everything....drove around....still the banging sound, which really does sound like a TON of parts are loose and literally bouncing around....WTF
So this morning, I take off the rear strut assembly, undo the bottom bolt on the bottom control arm....and the WHOLE DAMN COILOVER falls out!!!
[O_O]
After taking the whole thing out, found this....The weld on the top of the strut just broke.....check it out...
Heres what the weld SHOULD look like
Now the obvious question is...how the HELL do i get this fixed? The strut itself is still in perfect condition...no leaking oil or anything.....but that weld just needs to be fixed. Can I just go to a regular welder to get it fixed, or do I have to send it directly to KW?.....I'm hoping this won't cost a lot of money, cuz i'm workin on some other things for my car right now, so someone PLEASEe give me some good news....
