Results 1 to 19 of 19
    Rest in Peace Four Rings adam's rotors's Avatar
    B9SQ5 | B9S4 | HD FXLRST
    1.8t vs. 3.0...REAR rotors differ?
    im getting two different part numbers from my supplier, but i never thought they were any different...
    ...we did a misorder and got a set of 3.0 rears instead, and were not going to take the chance...
    thoughts/idea/info/specs?
    ...just wanna clear this up for future orders so i know...
    *i have a special on a set of b6 3.0 rotors, FYI!
    normal $350 for a set ($300 base with +$50 3.0 sizing)
    ill do this set for $300 to your door
    they are SLOTTED only...ready to ship!
    thanks for the help guys...
    adam | adam's rotors inc. | [email protected] | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    Feb 17 2005
    Sarasota, FL
    Re: 1.8t vs. 3.0...REAR rotors differ?
    245x10 and 255x10
    02 - Early 04' 1.8T's use 245x10, Late 04' - 05' 1.8T's use 255x10
    All 3.0's use 255x10
    my man...always a help shawny-boy...
    thanks bud
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by Adam@SPP View Post
    thanks bud
    No problemo!
    And for those curious, you can call the dealer with your VIN number and they will tell you what size rear rotors your car came with!
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Quote Originally Posted by A4ringedONE8T View Post
    245x10 and 255x10
    Actually, I think its 245x10 or 255x12
    8E0 615 601 P = 245x10mm
    8E0 615 601 D = 255x12mm
    Adam, both sizes came with the 1.8T so you can use some of those you already bought but make sure they check what they had on stock.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    ok now this is more confusing...
    3.0 being 255x12mm?
    id imagine the same years apply to the 1.8t options that shawn mentioned? just his dimensions were off?
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by actlsub9 View Post
    Both are 10
    http://www.ecstuning.com/stage/edpd/...productID=3112
    Jun 13 2005
    Audi
    They may be wrong, from what I remember...
    8E0 615 601 B = 245x10mm
    "P" is now the replacement part for "B"
    "D" came on all 3.0's and later 1.8T's
    I could be wrong as well...
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Feb 17 2005
    Sarasota, FL
    Our Stasis rears are even 10mm still!
    Aug 26 2005
    According to the latest ETKA, 245mm rotors are 10mm thick, and 255mm rotors are 12mm thick.
    ...fuckn audi
    Sep 23 2006
    Houston TX
    I'm swapping mine out in a week or two so I can measure for you, but may not be soon enough for you. I don't have a caliper, otherwise obviously I'd measure them on the car.
    Jun 13 2005
    Audi
    I know that, but as diagnosticator said above, the 255's are listed in the ETKA as being 12mm.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Three Rings LawDawg's Avatar
    Feb 20 2008
    Naperville, IL
    So just to confirm, since I have a 1.8T ('05 USP) and am going to do the 3.0 brake upgrade:
    My rears are the exact same (b/c I have an '05) as the 3.0, and I only need to do the carriers and rotors on the fronts. Is that correct?
    Current:
    '13 S6 Prestige [Oolong Grey Metallic, B&O, Innovation (HUD, Night, ACC, Active Lane/Side Assist., Top-view), Cold Weather, LEDs, 20"]
    Former:
    '11 S4 Prestige
    '05 A4 1.8T USP 6MT
    '01 A4 1.8T QMS
    '95 Dinan M3
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by LawDawg View Post
    Who knows
    Jun 13 2005
    Audi
    For the rears, yes they should be the same. You can pull off you wheel and check the part numbers with the ones I posted above to make sure.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Three Rings MarkChai's Avatar
    Feb 01 2007
    1998 Titus Quasi-Moto
    SF, CA
    Lol
    Formerly:
    B7 A4 Saloon CVT :P
    C4 A6 Avant Quattro
    B6 A4 Avant USP 6QM
    B5 A4 Saloon Q-Tip
    Feb 20 2008
    Naperville, IL
    I certainly can, however since an impromptu wheel removal during the middle of a work-week is somewhat anti-fun, I figured I'd ask and perhaps save myself the trouble.
    I put an email into Craig at GenuineAudiParts, hopefully he can confirm. I'll post his reply when I hear back...
    It would be nice if my 3.0 brake upgrade (if you can call it an "upgrade") needed 50% fewer parts!
    Current:
    Former:
    '11 S4 Prestige
    '05 A4 1.8T USP 6MT
    '01 A4 1.8T QMS
    '95 Dinan M3
    ^ your should come to me for those rotors too...
    i have this set on special...or i can make a set for you
