Originally Posted by
dmoney1282
Although the PC would be more effective than by hand, if you don't know what the you're doing isn't there also a much greater chance you can damage your paint by applying to much heat/friction? Making the paint even worse would be my biggest fear.
With the PC, there is a very minute chance of damaging the paint. At a speed of 6 on the PC, you can rest your hand on the pad and it won't hurt your hand. If you apply a certain amount of pressure on a PC, it automatically reduces movement. The only way you can hurt the paint while using a PC is by over angling it and having the backing plate of the pad hit the paint. If you manage to do that, your mind's on something else while looking away from the paint. A rotary on the other hand will burn your skin off. It creates that much more heat.
So if the PC is like that, how is that better than by hand? It's more efficient. It's a great
finishing tool. For more severe paint correction, you'll have to step up to a Flex or rotary which utilizes direct, circular motion.
As far as cost, you can get a Pc for about $105 shipped. I've had mine for 10 years now and it's still going strong.
I imagine Flex, which is from Germany, will have a very good longevity too. Over the long term, both a good investment as far as results achieved, value, and time saved. Flex is a great combination of the ease and use of a PC but the effectiveness of a rotary taken down a few notches for good measure.
