Ah HA! That is your problem... Did you recently replace your cluster? If you did, do you have the old one still? You need to recode a couple of other things... One more thing... Give me the soft coding... THEN, go through and give me the measuring block values for the following... Actually, I will give you what the values "Should" be... WRITE DOWN YOUR OLD VALUES FOR THE FOLLOWING ALSO! In case something goes wrong, just revert back to the previous values... (The channels below the measuring block correspond to which adaptation channel they go to.)
Soft Coding = 02244
Measuring block 10
Ch 30 - 128
Ch 9 - N/A
Measuring block 11
Ch 4 - 2 (or 1 if you want German displayed in center cluster)
Ch 3 - 100
For block 125, you should read 1 0 1 0...
Measuring block 125 - Powertrain data-bus participants (Corresponds to Adaptation Ch 60)
Field 1 - Engine - 1
Field 2 - Transmission - 0
Field 3 - ABS - 1
Field 4 - ADR - 0
Now for measuring block 125, you need to go to adaptation ch 60 to change these... Really, here in America, you should only have Engine and possibly ABS... So the value you need to enter here in Adaptation Ch 60, is 00005. You may need to add 1024 to that value, for an entry of 01029. That is what it is supposed to be but my car didn't take it. Either way, what you are doing is adding that the engine and abs send information to the cluster...
I am assuming that you have the radio information on your cluster? If not, that will be similar as above but with different values/channels/blocks...
After you have performed the stuff in this post, go back to the previous ones and redo them...
