Results 1 to 20 of 20
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    Lightbulb OFFICIAL ROSTEN RODs THREAD (ROSTEN vs OEM pics - BWW)
    i have no idea how that tiny lil bolt is stronger than that big ole OEM one. ARP, tho...
    FYI, notice how the OEM rod is rough where they meet... that is bc they are cast in one piece and then cracked apart.
    TINY LIL ARP BOLTS...
    549.4
    582.5
    Thoughts...
    (Jared please share your pics)
    PRICE: $1250 retail/shipped
    582.5
    549.4
    -33.1
    x 6
    198.6
    sorry for the super large text... lol... make it official... now we know the exact weights of these rods.
    33.1 x (6) = 198.6 grams
    of weight savings from the bottom end/rotating mass should provide some sort of performance, even if marginal. soon we'll find out... and we'll also find out what they can handle. cuz, ill be throwin all i got at em. boost or bust. that is all.
    ps- if yall know any other rod brand weight pls post - n dont hack this thread. Thank you.
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Re: OFFICIAL ROSTEN RODs THREAD (ROSTEN vs OEM pics - BWW)
    almost half a pound in saving
    Jan 11 2007
    Salt Lake City, Utah
    did the ARP bolts come with the $975 price?
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    Anyone know if Pauter also makes rods? They've had a very good rep with VWs but don't know if they have stuff for the S4.
    Veteran Member Four Rings PinoyS4's Avatar
    2018 catalunya RS3
    sf bay area
    h-beam rods ftmfw
    work hard, play hard[;)
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    How about some Forged rods?
    btw, after you install the con rods, what is needed to balance the engine? Are ARP's actually just replace and ready? Someone mentioned that on here once, is that correct? If not, whats involved in balancing an engine?
    Mar 30 2008
    01 Black S4
    Ohio
    The cracked cap technology makes the rod caps line up better. Rods with dowels are a better setup, but more expensive to produce. The ARP bolts are a different metal and are tempered differently. They are much better re: tensile strength and stretch.
    Boris, these are forged rods. Balancing depends on the use of the harmonic balancer and flywheel. Most factory engines use an imbalance setup. The crank damper and flywheel are weighted to offset the imbalance of the rotating assy. Zero balance uses balanced damper and flywheel with no imbalance to offset. Zero balance is the better way to go. It's all about defeating harmonics that degrade performance and beat motors and drivetrains to death.
    Aug 11 2005
    Question Re: OFFICIAL ROSTEN RODs THREAD (ROSTEN vs OEM pics - BWW)
    Quote Originally Posted by jibberjive View Post
    YES, or course. almost all rods come w a preferred size and brand of bolt w it. most being ARP something or other. these have ARP 2000 bolts (tiny).
    Yes, they def make rods for us. in fact, i believe they weigh and cost more. but to get it right (apparently) you have to get in touch w Pauter first and send them one of your own. the reason being is bc apparently there are 3 diff rods for our cars. n he sends you the exact one, not just some 1-size fits all. do you guys remember Jeff Moss w the RS6 build. the car that was in the magazine. he experienced this w Pauter.
    * 2.6 liter
    * 2.7 liter biturbo
    * 2.8 liter
    * DO NOT FIT 2.4 and 3.0 liter V6
    * 154mm center - center
    * 21mm small end with bronze bushing
    * 57.6mm big end
    * 2piece forged from 40CrNiMo steel
    * shoot peened and heat treated
    * comes with ARP 2000 bolts and assembly instructions
    * weight is 555 gram included bolts - funny, it is actually less
    * with a tolerance of +- 1gram
    as for balancing etc... i do not know the exact process. and as for bolts... i think you may be referring to the matrix con-rod bolt thread. these are different size bolts than the M8.5 OEM bolts. random factoid... RS4 uses M9 OEM con-rod bolts.
    Veteran Member Three Rings ss4's Avatar
    Jun 04 2005
    San Diego
    Quote Originally Posted by JayyyyyC View Post
    Yes, Pauter makes an awesome rod for this motor. Have them in my car...
    Aug 06 2007
    audi, subaru, dodge, ford
    Truckee, CA
    Price is wrong, that was part of a group buy. Wont happen again.
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    cant wait to get this bad boy running :)
    Aug 11 2005
    Quote Originally Posted by Jared@STaSIS View Post
    LOL! thanks for sharing.
    Aug 06 2007
    Truckee, CA
    Good thread and info man, thanks. Here are a bunch more pictures. Prepare for info overload...
    Btw- These are the s4 fit, there is also an RS4 direct fit.
    The only difference is the big end bore.
    56.8mm on the RS4
    57.6mm on the S4
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by generationjdm View Post
    yep, about 0.43lbm to be exact. but you'll see much more in terms of linear & rotational inertia, which is what is important. if someone has the exact rod dimmensions handy (or *dwg files better yet!), I could calc. this value...
    otherwise, just suffice to say the engine rev more freely, possibly in comparision to a LWFW.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Aug 11 2005
    Quote Originally Posted by BITRBO View Post
    Jared, post those dimension pics so i can see this math!!! thanks in advance!
    Aug 06 2007
    Truckee, CA
    Done
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by MiniRS4 View Post
    damn.... called my bluff well I'll give it a whirl next week after I get the P.E. out of the way (this Friday).
    which reminds me... I shouldn't even be on here
    DOHPE!
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Feb 08 2008
    01' 2.9L GT S4 racecar built for TA/GTS competition
    North Jersey
    its too bad a 5/16th rod bolt is the largest these rods can take, a 3/8th would be sweet
    Feb 08 2008
    North Jersey
    also the reason why they look so tiny is because they only need a small amount of threads, they are special rolled threads that companies like arp specialize in :) Strong shit
    Dec 20 2005
    District 7
    Sorry, I thought Forged was a brand as well as being a type of con rod
    Hey, are their any con rods that can be repalced into the s4 engine that are just plug and play, with no need to balance or anything? Just replace?
