Results 1 to 40 of 71
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    My new Bipipes and ofcourse before and after logs
    Finally got a chance to install my new bipipes, I was amazed how these don't even weigh anything at all.
    Here are the Logs, Same Road, Same IAT, Same Software no change..
    RED= CATS
    PINK= NO CATS
    BLUE= NO CATS NEW BIPIPES
    As you can see i gained more top end power :) guess the stock pipes are too small for GT turbos and choke them up.
    Senior Member Two Rings WingsnHorns's Avatar
    Feb 09 2008
    '00 S4
    Vancouver
    Re: My new Bipipes and ofcourse before and after logs
    Very nice!
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    Question Re: My new Bipipes and ofcourse before and after logs
    very informational post.
    any impressions of the before n after? like spool, feel, sound, etc...
    also, how much did they cost and where can i get them?
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    Don't worry JDM, haters will still bash it because your a no name...oh well, I think everyone will eventually sucumb to the Generation X products tho:)
    Feb 17 2008
    Ottawa Ont.
    how close to the stock fan are they? looks tight
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    ^ Don't think theres a fan there anymore :).
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Jun 14 2007
    2000 S4
    Connecticut
    yeah no, greg has a thing against the stock fan lol, but i think genx mentioned somewhere else that it will be like a 1/4 inch away ..? correct if im wrong!
    Mar 14 2007
    michigan
    He will have one on the motor with a stock fan to see what the clearance is soon
    Sep 19 2006
    Boston
    It shouldn't matter if hes a no name if his products are good theyre good,
    Sadly in the audi scene its not like that. SSP and other starting companies still gets bashed by other companies when its they who should be getting bashed...
    B5 Imola S4
    B9 Black SQ5
    B7 Silvaro S4
    Veteran Member Three Rings cjk's Avatar
    Jul 15 2004
    2001 WB S4 Avant
    Seattle, Wa
    Looks like another nicely made product with results! :)
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    nice logs, real world facts are better then advertising a product with no stats like others do
    Established Member Two Rings kido81's Avatar
    Jan 15 2008
    Staten Island, NY
    generationjdm- These are the pipes you have been working on??? when are you going to be making these?? i am def. down for a set...
    Active Member Four Rings
    Dec 11 2006
    Boston
    Nice.
    Would merging the bi-bipe by the throttle body into one straight pipe to the throttle body, allowing for just one coupler from the throttle body to the bi-pipe...would that benefit at all? Considering there would be less of a chance for any leaks by only having 2 clamped down areas, as opposed to the 3 that the current setup/tbb has?
    Stage 3+ RS6's
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    Ok... looks like the pipes did nothing. They're pretty though...
    B7 S4 Avant
    Dec 11 2006
    Boston
    Up top acceleration is improved, which is where it was being held back.
    Stage 3+ RS6's
    Dec 03 2007
    Potomac, MD
    these new pipes have a bigger ID, right? if so then i dont doubt an increase in power
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    The aluminum bi-pipes does not taper down to 1.5"! Its 2.0" through-out the length of the bi-pipe!
    Last edited by Daft; 04-10-2008 at 12:05 PM. Reason: Clean up of posts from TipsyS4
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by generationjdm View Post
    IMO, this will be the key point of this set of BiPipes. If they do not, you are looking at a very limited set of customers that will be able to use them.
    I would also prefer to see them mate up to a RS-4/late model Allroad-like metal TBB as oppose to Samco or other flexible TBBs.
    Feb 29 2008
    Durham/NC/Southeast
    Quote Originally Posted by SilverSurferS4 View Post
    GENJDM said it is actually 1.92 id. in the other thread fwiw.
    Now since I said i would I just did a quick test on the flow bench. VERY QUICK and plenty of room for error but I did all 3 set ups twice. Using a stock throttle body with a stock boot on it I flowed it at 10" of vacuum. The stock tb with boot and no pipes flows 295 cfm.(This adjusts to about 493cfm @28" I believe) with the stock bi pipes in it flows 260cfm. With two 2 ft straight sections of 2" ID pipe jammed into the boot it flows 290cfm. I don't know what a bent 2" id pipe or 1.92 would flow.
    Mar 14 2007
    michigan
    1.92 I.D the 1.52 on the stocker was I.D also... So the 2 inch pipe flowed over 10% more.. On the car theres tons of other Variables..
    Dec 03 2007
    Potomac, MD
    seriously, you have no idea what you're talking about. why don't you stop your bench racing and try something out before talking all this garbage?
    the 300zx community which has a very similar setup to the s4 tried switching all of their piping all the way from the air filters up to the throttle bodies (and everything in between) from 2" to 2.5" ID and saw gains of 10-15whp, WITH NO OTHER MODIFICATIONS.
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    Looks like APR is going to have to discontinue their bi-pipes! =D
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by JayyyyyC View Post
    Probably not, as most people buys APR BiPipes to avoid TBB tears or TBB popping off under boost and other TBB-related malfunctions, not for the purpose of performance gains.
    Dec 03 2007
    Potomac, MD
    um, that's dual 2" piping on a v6 twin turbo 300zx there, chief
    so you've been racing since '58? that makes you at minimum 70 years old
    Last edited by Daft; 04-10-2008 at 12:06 PM. Reason: Clean up of posts from TipsyS4
    Dec 03 2007
    Potomac, MD
    what is the ID of the ic piping and intake piping? consider that, then ask yourself if having 1.5" piping is contributing to some restriction aside from the obvious which you mentioned
    Mar 14 2007
    michigan
    Soslow, don't waste your time there was a dozen key points he never answered, this is purely entertainment fun for him....
    Veteran Member Four Rings raketeS4's Avatar
    Feb 14 2006
    2000 B5 S4 Stg II+, 1977 BMW R100/7
    anyone willing to hack up their APR bipipe and tell me what the ID is?
    2000 B5 S4 Stg II+
    Sep 19 2006
    Boston
    why would you need to hack it up lol just get a set of calipers to measure it...
    B5 Imola S4
    B9 Black SQ5
    B7 Silvaro S4
    Account Terminated Three Rings pzp107's Avatar
    Dec 02 2007
    State College pa
    This is actually a very simple flow calculation you would do in any freshmen thermodynamics class. You are increasing the volume of air traveling through the bi pipe. You are WRONG in saying that the throttle body and everything else is the same restriction which would net no increase in horsepower. If you want a an example like your garden hose problem think of the throttle body now acting to take the larger volume of air and increase velocity by forcing it through a smaller hole. This would in turn help feed high rpm power. This is a common principle opposite of a diffuser, guess what it is? You are right in saying a larger throttle body, manifold, porting etc would be beneficial. But thats about the extent of your correctness.
    Long Island, NY
    yea umm i didnt launch my car i never launch on my first run..
    Marc why you still trolling
    Feb 29 2008
    Durham/NC/Southeast
    the thing that gets left out in the modern times is the poor old cylinder head. People get so lazy and think that turbos will fix all. the bottom line is flow thru those valves is where the power is made.
    Seriously though 12s????
    Long Island, NY
    yes 12 couldn't go again since the track got rained out. I know for a fact if i would of launched my car would of beat my time and trap
    Long Island, NY
    marc im not responding to this thread anymore it might as well be closed.
    Dec 17 2004
    US
    I had a strange feeling about this Tipsy character. Marc at his finest.
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by pzp107 View Post
    Uhhh, I don't know about "simple", but I know what you were getting at Actually, you have forgotten the other major component to the Q=V/A story... Velocity. By increasing the diameter you do increase flow, however, you also decrease velocity (for a given temperature & pressure). This is all in a perfect world of course, but as we all know there many "real" world factors that can effect these values in either direction. Let's just suffice to say that the charged air supply entering the TB may have more volume, but it's entering at a slower rate (unless the pressure is increased). And may I ask where the hell Double Nutz is at a time like this???
    But to "Tipsy's" point, there is no denying that there is only so much the stock S4 heads can physically flow (per increment of time), based primarily on volumetric limitations and timing; the valves can only pass so much air before they close, indicating that flowable volume, smoothness, and architecture of the intake track play a critical role in the whole event. Then you have to contend turbulant flow, eddies, etc., etc. and then it get's really messy. I would venture to guess that Z-German engineers who designed this engine sized the bi-pipe within marginal limits of the engine's flowable capacity (I'm also guessing that APR realized this also, hence their I.D. size is approx. stock too).
    Therefore, it is entirely possible that genjdm has taken out some of this proverbial "fluff" in the system (at a particular engine speed, intake presure, temp., etc.), and provided another piece to the puzzle. Now my guess is that if Gregg threw a cam in there with a little longer intake duration, things would start to get interesting.
    But as entertaining as this may be to "Tipsy", he does have some valid points. Although controversial, he is actually asking good questions that we should all be asking ourselves anyways. Otherwise, how else would we push the envelope gentlemen?
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jan 24 2006
    Ohio
    So i'm supposed to believe that a .5G increase in acceleration up top (according to those logs) is primarily a result of the bipipes?
    B7 S4 Avant
    Feb 14 2004
    Michigan
    Wow! So many fools...can the guy get a few more trips to the track for some fine tuning without every douche bag here getting his panties in a bunch over the ET and Trap, gosh!
    Mar 14 2007
    michigan
    Quote Originally Posted by revhards4 View Post
    What they didn't hear is he only made 1 half ass run where he was still was 3mph faster in the 8th then the last run when he rolled out of the whole...
    Veteran Member Three Rings ToMMyRsK04's Avatar
    Dec 26 2006
    2000 audi s4
    New York
    trolling FTW
    bye bye AWE Stg 3+ and HeLLooOo ........
    For Sale
    - VAST Port & Polished Intake Manifold - BEST OFFER
    - Stock B5 S4Pistons/Rods/Valves/Springs/Retainers/Cams 44k on them
    - Two GT3076 Turbos
    Senior Member Two Rings Kindbuddy's Avatar
    Nov 05 2006
    2000 Integra GSR
    San Antonio
    Just to add my 2 pennies...(tipsy) If you add more flow behind a certain restriction, you get more flow through that same sized restriction. Even if it's a fraction. I learned that through ten years of speaker box building and port tuning.
    "You can buy muscle, but you can't buy cajones"
    01 S4
    Your check engine light isn't on? Is your car ok?
