    Registered Member Two Rings 1sika3's Avatar
    Sep 04 2007
    '06 Audi A3 2.0T
    Westborough, MA
    Blown DV, or at least it appears to be!
    So i'm at most convinced that finally my Diverter Valve has blown, the times past it's been little things.
    Example: Last time I had no boost pressure, my oil plug had come off. My DV made no noises that would indicate that it was failing.
    Now this time, I've checked for oil spraying anywhere in the engine bay with no luck.
    However, when I accelerate rapidly, my CAI builds u know the pressure and sound of the turbo spooling up. I release the gas pedal and it releases the air that was circulating, but after that, short delay between the two, it sounds like all of a sudden I have a SSQ Blow off valve, which I don't.
    But i've noticed I have absolutly no boost pressure at all. Driving home from AMC 24 tonight over in Highlands Ranch, I noticed that when hitting the throttle the car was producing no boost, and felt rather slugish.
    So I am assuming that the DV is blown, had a Check Engine Light on this weekend, but however, it has gone away since and has yet to appear again.
    Can someone please help me to try and diagnose this problem!
    -Rob
    CEL Free since 03-05-2007
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Re: Blown DV, or at least it appears to be!
    Have you checked for boost leaks?
    I know for us 1.8T guys, a common place for a leak would be the vacuum line that connects to the intake manifold. Check there. You do have a boost gauge correct?
    Do 2.0TFSI motors have a throttle body alignment process? If they do, try that as well.
    ÖMGHI2Ü
    Photography
    Registered Member Four Rings
    Apr 24 2007
    Great Lakes of SoCal
    Quote Originally Posted by 1sika3 View Post
    -Rob
    sounds like the DV to me..happened to me a lot no worries
    Got Oetty?
    www.DiscountTires.com
    Just updated!!
    Registered User Two Rings
    Sep 04 2007
    MK5 GTI
    Orlando FL
    It certainly sounds like the DV.
    I sent you a PM about how to go about inspecting it.
    Sep 04 2007
    '06 Audi A3 2.0T
    Westborough, MA
    Quote Originally Posted by Mike@Forge View Post
    appreciate the PM will be checking into that tomorrow when I get a chance.
    Does it matter that my CEL no longer appears?
