Results 1 to 35 of 35
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Stasis SS with conservative drop
    After trying different settings I settled with 25.75" at the rear and 25.5" at the front. This is down from OEM sport 26.5 R/27F
    I don't know if it's the better settings for track but I love the looks. I believe that an A4 with OEM wheels just doesn't look right if it's too slammed - but that of course is only my opinion -
    I wanted to post this for folks that want to greatly improve handling but don't want to look like they have the trunk full of stones when they load the rear seats with family or friends. Koni shocks and springs combo is superb. The ride is almost like OEM and the only element that makes my rear a little rough is the RS4 sway bar (but it turns so good!!)
    EDIT: by the way, can you see the 3m clear bra?
    [IMG]http://homepage.mac.com/tribe3/.Pictures/a12.jpg[/IM]
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    Re: Stasis SS with conservative drop
    looks great! thanks for the measurements, i'm looking to do the same.
    i think i can tell the clearbra is on in the 5th pic (by the way the light reflects off the front bumper) but i could be wrong. did you do the install yourself?
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    Nov 12 2007
    Grand Junction, CO
    The front is supposed to remain a little higher than the rear, I believe.
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    LA
    Looks great. Is that the preadjusted height Stasis sent to you? I think i would lower it another 1/4in in the front/rear. Also like stated above, to keep the proper cornering weight/balance, the front needs to be a lil higher. The spacers also set off the OEM wheels a lot.
    (Ka-La-Bre-Ah)
    Veteran Member Four Rings SLYCAT's Avatar
    Sep 26 2007
    Augusta
    Looks good, I like the slight rake it has. but won't it affect perfomance?
    Feb 15 2008
    lotsa tools
    Vienna, VA
    I know the front has to be higher; it makes sense. Actually the gap is slightly bigger in the front, but I tuned it more for an even look rather than performance. Anyway I went to some twisties close to home and it turns very good! Much better than OEM sport, and with the rs4 sway bar it is very neutral - no noticeable understeering.
    The preadjusted height is not something I could be certain of because all the perches were loose... I did the try and error method. I also figured out how to adjust rear height without taking off the springs! You have to cut the wrench an inch; drill a hole at the extreme and attach a rope to the end. Depending on the side and if you are lowering or rising you can either adjust by hand or set the wrench in the notch and pull the rope from the inside and under. (a helper is useful but you can do it alone too)
    One full turn of the rear perch is a 1/4". Height varies with camber adjustment.
    The bra was installed at the dealer.
    Senior Member Two Rings montess2001's Avatar
    Jan 20 2008
    Westchester, NY
    what was the stasis height out of the box? Your car looks awesome btw !
    Current: 2015 SQ5 / 2016 ATS-V 6MT
    Mods: 034 Stg I + TCU / H&R+B8 / Neuspeed Rse103 20x9.5 et 25 / Carlinkit
    Previous: 8V S3 Daytona launch ed. / E92 M3 6MT / E39 M5 / B7 A4 Ibis 6MT Ti big turbo.
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Looks GREAT! It has about the same height-stance that my car has (with my personal settings). Looks like I started a performance-oriented trend in height settings
    2006 Audi A4 2.0T Quattro 6MT S-line
    Senior Member Three Rings tivs31's Avatar
    Feb 07 2008
    Lemont IL
    it does look really nice with the stock wheels like that, not goofy at all, so good work
    Active Member Four Rings SEXICN's Avatar
    May 20 2004
    More cars
    Never Land Ranch
    did you even lower it? LOL, jp looks a lot better!!!
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Perfect! I'm raising my car back up. Suspension lower than that doesn't work. Trust me, I've done it twice- B6 and B7.
    "Obsessed" is a word that the lazy use to describe the committed.
    Senior Member Two Rings A4CE1's Avatar
    Feb 10 2008
    06 A4 2.0, 03 Wrangler, 96 XJ
    Westchester, NY
    forget everyone who thinks it should be slammed to the ground. i LOVE how small the gap is around the tire but most of all i love how it's even all the way around. it looks so right. nice job.
    ps, my s/s are going on tomorrow, i think i just stole your measurements haha
    VW Touareg V10 TDI. Don't mess.
    Past: Stg. 2+ B7 2.0T, B6 A4 1.8T, Allroad 2.7T 6spd (<-monster), Chevys, Jeeps, and a Nissan.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you, Body kits and decals are how much of a mess you leave on the wall.
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    I think it looks great! I wish I could lower my front end just a touch more...but I can't.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    The height is absolutely perfect. i have never seen a better looking suspension kit
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Senior Member Two Rings skistud's Avatar
    Mar 21 2008
    Moro Blue 06 A4 3.2 S-Line
    Chicago,IL
    ya the car looks great man, i think im going to steal your measurements as well when its time to bring it down, just got my car 2 months ago and am just saving up for my mods, so ill post when its dropped.... looks great though
    Veteran Member Three Rings WantAvant's Avatar
    Oct 12 2006
    04 A4 Avant 1.8T
    Sioux City, IA
    Quote Originally Posted by autoverrückt View Post
    You should just switch your Eibach pro-kit for the H&R sport springs, they will give you a little lower stance with a slight rake in the front. That is if you don't want to spend the cash on coilovers.
    DUH! an Audi
    los angeles, CA
    car looks very very nice, i hate threads like this makes me wanna lower my car... must fight the urges
    -randy
    Senior Member Two Rings ruckus's Avatar
    Feb 18 2004
    here/there
    The drop looks awesome... thanks for posting a reference point for us. Just got my Stassis C/O's and this will be my setup.
    OEM: 2006|A4|SLine|6spd|FWD|BrilliantBlack
    OEM++:StaSIS Coilovers|RS4 Grill|APR Tuned Stg2+|APR HPFP|ATP Downpipe|034 Silicon Intercooler Hoses|AutoMeter Boost Gauge Podi|Carbonio Intake|Staggered BBS LM F1 Edition F18x8 R18x9 ET35 235/40/18|OEM Roof Racks|Cold Air Fog Light Delete|Cupra Lip|3M Matte Black Wrap|Relak Side Skirts|034 Adjustable Upper Control Arms|034 Solid Rear Sway Bar|034 Catch Can|RNS-E
    @rezmoto.com
    AWD_4TW
    Quote Originally Posted by Quattro View Post
    -randy
    Wait, you still haven't lowered your car yet? Even I'm lowered now man
    Registered Member Two Rings OceanBlueB7's Avatar
    Oct 15 2007
    Ocean Blue Pearl '06 A4 2.0TQT
    Boise, Idaho
    I can't see the ClearBra lines at all. Nice work.
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    Thanks for the measurements. I'm getting FK coilovers in a week or so, but I'm putting on 19s. It's nice to see some numbers to go by as I don't want mine slammed either. I'm looking for stock RS4 look similar to your clearance.
    Jan 06 2008
    Dacia Sandero
    Arizona
    I think thats the perfect drop. Looks good!
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Strn . 034 . OEM+
    Sep 26 2004
    STL
    Quote Originally Posted by AudiWxGuy View Post
    I have made this statement in previous posts...but I just now realize it was based on settings for V8 S4! Damn.
    05 S4 6MT silver
    Present:
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    Conservative Street Setup
    Between 1/16 and 1/32 TOE IN front and 1/32 TOE IN rear
    Ride height at 25.875” front and 26.000” rear
    (–1.0 camber front)
    Aggressive Street Setup
    Between 1/32 and 0 TOE IN on all four corners
    Ride height at 25.500” front and 25.625” rear
    (–1.5 to –1.75 camber front)
    Track Setup
    Between 0 and 1/16 TOE OUT on all four corners
    Ride height at 25.000” front and 25.250” rear
    (–2.0 to –3.0 camber front)
    4Runner, Rs5 and Alfa Guilia QV
    AWD_4TW
    Wups, understeer country here we are
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Quote Originally Posted by Groove1797 View Post
    (–1.0 camber front)
    Track Setup
    That's good info. I couldn't find it in the Stasis webpage. I guess I fit in the aggressive category
    So the front is lower than the rear on all setups... I can't blame 'em; it looks better.
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    nice drop, can't wait to get my stasis ss.
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    Veteran Member Three Rings quattro.it's Avatar
    Mar 24 2008
    2004 BMW R1150RT
    Bellevue, WA
    I think it looks perfect. Can't see the clear bra at all. I've always been a firm believer in function over cosmetics, it's non-negotiable. That's why you bought a quattro, right? You've done the perfect setup w/Stasis CO's and spacers, great reference material for the rest of us.
    2007 A4 2.0T quattro Tip S-Line Titanium / Lava Gray / APR 91 /
    Mar 02 2007
    Brisbane, Australia
    Question Re: Stasis SS with conservative drop
    Nice drop ! Pretty much what I'm after for mine - gotta keep it practical
    How is the ride quality of the Stasis SS compared to OEM Sline Sports suspension ?
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Ride is good. Sporty firm but not harsh. Better than lowering springs alone.
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    what clearbra?
    Senior Member Two Rings hachirokukid's Avatar
    Mar 22 2007
    00 S4, 07 A4 2.0t
    nc
    wow....my wife has the same car and i am waiting for some cash to drop...
    your drop looks awsome!!!
    Veteran Member Four Rings dreamcar=rs4's Avatar
    Nov 04 2007
    A4 2.0T
    NorCal
    Quote Originally Posted by tribe View Post
    car looks great
    is there even less body roll compared to oem sport suspension?
    May 20 2004
    More cars
    Never Land Ranch
    Quote Originally Posted by 4RingRook. View Post
    Stop thinking, LOWER it further! I can still see the top of your tires!
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Registered Member Two Rings Ski DraGoN's Avatar
    Sep 24 2007
    fl
    Looks real nice.
