Results 1 to 15 of 15
    2003 A4 1.8TQM
    Markham, Ontario
    Liscence plate light question
    Had this bulb out warning come up in the center screen
    Before I start taking the car apart, I thought I'd better ask - is changing the bulbs as simple as unscrewing the covers from the trunk lid on either side of the trunk release, or is it more complicated?
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Re: Liscence plate light question
    just unscrew the covers from the trunk lid and ur done.
    thats if ur lucky and ur screws arent rusted or damaged or stripped. becareful when taking them out because they strip very very easily!
    2003 A4 1.8TQM
    Markham, Ontario
    Good to know. Think I'll be stopping on the way home tomorrow for some bulbs, and a philips socket to get the covers off (stupid screwdrivers won't quite work due to the angle )
    May 24 2007
    Southern California
    ya, definitely use a 90 degree philips.
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Three Rings TurboQuattroPwr's Avatar
    Sep 28 2006
    Delaware
    Be very careful, I stripped mine trying to replace the light last week. Time to drill it out!!!!
    2018 Audi S4 3.0T
    18% Tint, CquartzPro Ceramic Coating
    2002 Audi A4 1.8TQM *Gone*
    Established Member Two Rings vtecgreen's Avatar
    Jan 07 2008
    St. Louis, MO
    Mine were stripped, so I had to drill Out, PITA.
    Get some LED's!
    03 1.8tqm All show, no go. Yet.
    6000K HID Fogs| LED License plate lights | Tint: 20% Rear / 30% Fronts | Lip Spoiler | 19x8.5 ADR M-Sports
    Veteran Member Four Rings Onese1f's Avatar
    Jul 22 2007
    01 A6 2.8, 03 3.2 CL
    Sunrise/Orlando, Florida
    Quote Originally Posted by vtecgreen View Post
    Get some LED's!
    Nice color output.
    What spec are they?
    I was lost, and I'm still lost...but I feel so much better
    Jan 07 2008
    St. Louis, MO
    UH.
    Ive had them for a year, got them at www.superbrightleds.com, they are 39mm with 6 LED's I believe.
    That's about all ive got on em.
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    What size drill bit did you use to get the screw out? I stripped one of mine too. Why that had a gorilla tighten a dang license plate light cover I'll never know.
    GO KNIGHTS!
    Jan 07 2008
    St. Louis, MO
    I used a screw extractor or something - its a kit that has corkscrew like drill bits that get lodged into the screw. I got lucky, it actually worked. Should be about $10 at local big box hardware store. - its just a PITA because my drill, borrowed another one because it was smaller - those screws are in a tight spot!.
    Senior Member Three Rings jonsaudi's Avatar
    Jan 09 2008
    2003 A4 1.8T tip quattro
    California
    Ha..mine stripped too! Man, these screws are cheap. Where did you get the screws to replace the stripped one??
    • 03 A4 B6 1.8T • Tiptronic • Brilliant Black • quattro • Sport Pkg //18" RS4 style rims //35% tint //Zimmermann x-drilled //Hawk HPS //CF wrapped trim.
    Senior Member Three Rings riot5alex's Avatar
    Jan 25 2008
    03 3.0QM
    Illvine, CA
    yepp.. i got leds too and i love em! its the little things that make the difference. if you use a regular philip head.. i suggest taking off the license plate first.. it takes like 2 seconds to do and it helps a lot!
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Yeah I almost stripped mine... put it off and was at the dealer and they did it for free, the told me they had to drill them out.. :)
    Jan 07 2008
    St. Louis, MO
    I just went to the stealership and had them order me the lenses - it comes with the screw. I think one of the online audi parts stores has them for significantly cheaper
    2003 A4 1.8TQM
    Markham, Ontario
    Update:
    Managed to get the right side light out and bulb replaced, so at least the warning light isn't there anymore
    However, on the left....
    1st attempt: #1 phillips bit / 1/4 inch socket / 1/4 drive ratchet
    2nd: offset Phillips screwdriver
    3rd: minature box wrench / screwdriver bit set
    Then it stripped out
    So, I've got to attack it with the screw removal kit, once the cordless drill charges, but not until after I pick up replacement fasteners from the stealership.
    Unless I go LED.....
