Results 1 to 9 of 9
    Aug 12 2007
    Can't remove bolts holding brake calipers
    I'm trying to remove brake calipers. The bolts won't move. I have a 240ft/lbs impact gun that can 't get em out, been spraying lots of PB Blaster on them, even tried heating with a torch and they won't move. I don't know what else I can do, I don't wanna strip the bolts.
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Re: Can't remove bolts holding brake calipers
    Quote Originally Posted by evehill View Post
    Cheater bar.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Aug 12 2007
    Quote Originally Posted by Jsmooth65 View Post
    Cheater bar.
    Breaker bar? I don't really have enough room to swing one in there
    Aug 10 2007
    Castle Rock, CO
    Yes you do. Turn the wheel all the way one direction, so that the caliper is sticking out. You should have enough room to get a good 3-6" of breaker bar action. I've done it countless times.
    Aug 12 2007
    Okay I finally got it, just needed to curse a little more
    Thanks man ;0
    Dec 06 2007
    Calgary, AB, Canada
    ^2nd.
    Apr 05 2007
    Quote Originally Posted by The_Jerbel View Post
    ^2nd.
    Jordan was going to come over and help you, but he said you didn't have tickets to the gun show.
    Feb 17 2008
    Ottawa Ont.
    wait till you try that shit on the 11mm brakeline nuts.
    off to the shop for new brakelines.....
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by exorcet View Post
    LOL, how did you know?
