Results 1 to 10 of 10
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Help, CANT GET VALVE COVER OFF!
    I cant yank the thing off....ANy tips???
    Sep 24 2007
    Woodbridge, Ontario
    Re: Help, CANT GET VALVE COVER OFF!
    Bump
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    What do you mean?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by dirtybrd View Post
    What do you mean?
    Im trying to take off my vc to replace the gasket and I took the neccesary stuff off and it wont come off...
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Check to see if it's getting caught up at the back of the head. Sometimes you need to work it around a little to get it off...
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    When looking at the motor from the front check to see if the vacume lines on left above the turbo are holding it on becuase if my memorie serves me right I remember their being screws that hold the vacume to the VC.
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by CO AVANT View Post
    I had to put it back together. Its impossible to take it off. Too many 1 time use clips near the pcv
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Quote Originally Posted by audipotential View Post
    get a couple hose clamps from pep-boys and try again.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    How about the obvious?
    Did you loosen all the bolts?
    New one-time-use clamps for vacuum lines. Just choose a different size for the EVAP stuff out back.
    For documentation purposes....
    If you chose to replace the vacuum lines yourself here is the stuff I used:
    100% Silicon 4mm Black vacuum line. 10ft at $2.00 a foot from Baker Precision Products http://www.bakerprecision.com
    I'm sure you can buy them somewhere else but this is where I bought mine from.
    OE-style hose clamps from McMaster-Carr (I love this place. Its like walking into the Sears tool department.) http://www.mcmaster.com
    Part Number: 52545K42
    Item: Gap-Free Pinch Hose and Tube Clamp 5/16" to 3/8" Clamp ID Range, 13/64" Band Width
    Package of 25
    $6.82 / package
    Part Number: 6541K69
    Item: Side-Jaw Pinch Clamp Pincer
    $21.94
    Prices as of July 2005. They may have changed since then. Part numbers are still current.
    -Doug
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    my valvecover job was the biggest FPITA as well..
    Obviosuly it is on studs, so make sure everything is clear. There is the turbo oil line that must be unbolted (not removed just unbolted) from the back of the head
    -Sami-
