    Senior Member Three Rings Fiyacracka's Avatar
    Feb 13 2008
    HELP! Car is clunking, when coming to a stop
    I have a 2000 S4 and about two days ago, as I was coming to a stop, I hear a soft clunk and I could feel it in my feet. I know for sure that it is coming from the right side of the car. My dad owns a shop so I put it on the hoist, and absolutely everything was tight. Today it is getting louder and I feel it more and more. Any ideas??
    Dec 12 2007
    Boston
    Re: HELP! Car is clunking, when coming to a stop
    Control arms and tie rod ends.. they like to go in our cars :)
    mine are getting fixed this week.
    2001 S4
    Stage 3 totaled...
    new- 2001.5 Nogaro
    Veteran Member Three Rings Paulyworld1432's Avatar
    Dec 07 2007
    Houston, TX
    I had the same problem i think. Did you ever hear it upon accelleration? mine was when i applied the brakes and then when i would accellerate it would "pop" back into place... i think it was cause by forward momentum of transmission.... maybe bad tranny mounts? but i installed the DTS and the problem went away, trannymounts will be replaced when stage 3 occurs!
    Dec 06 2007
    Calgary, AB, Canada
    take the wheel off and check the brake assy.
    Feb 13 2008
    the only thing we really noticed is that the pads need to be changed soon. I feel the clunking coming from the middle of the car now and it is definately getting worse. I will try checking again tomorrow. thanks for the suggestions. I never have the problem when accelerating. if i downshift to a stop, nothing happens. only when i brake
