Results 1 to 17 of 17
    Sep 11 2007
    Dirty Jersey
    Boost Factory Bad Ass Mo' F'in Side Mount Inter Cooler For The Win
    I borrowed the words from a certain moderator (over on the TEX) , but I think its a fitting description
    so, I picked up this sidemount from Killa last night (his car is real fast btw)
    and went to put it on first thing this morning
    pics off the car:
    the install was a breeze, this deffinatly is the civilized way to mount an intercooler to our cars, it just popped in place. its really big, but it just filled the inner fender void perfect, it even lined right up with my S4 fender liner vent
    in another thread I saw some people pointing out that it doesn't have mounting tabs, I can tell you for sure, it doesn't need any it mount solidly and securly as its just the exact shape of the space in the fender, I can't imaging how long it took to get the shaping of the end takns just right
    the only thing that I trimmed in the install was the shroud, its probably not needed as any air comming in the bumper is forced over the intercooler as it has no where else to go, but I figgured it was worth my time to make it fit
    since the original mounting points were trimmed off I screwed it to the rad support with 2 sheet metal screws
    and with the bumper fitted:
    I'm real happy cause its 100% real world friendly, the bumper comes on and off just as easy as stock, the intercooler doesn't sit any lower than stock so I have no fear of rough roads or bad driveways and you can't even tell I have it :D
    oh yeah, and the car feels a bit faster with it on (buttdyno FTW)
    (sorry for the blatent fortitude repost)
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: Boost Factory Bad Ass Mo' F'in Side Mount Inter Cooler For The Win
    Paul C for the fucking win!
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Very nice.
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    noticible difference? like $550 worth of a difference?
    I like the support of up to 491CFM w/ ~1psi drop.
    Sep 11 2007
    Dirty Jersey
    Quote Originally Posted by djwimbo View Post
    I can't prove it with #s at this time, but to me it deffiatly seems worth it
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    thats beefy!! what turbo set up you using it with?
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Sep 11 2007
    Dirty Jersey
    k03 now, k04 pc16 in the future hopefully, the intercooler can support a much larger turbo but I'm imposing a limit on myself for only KKK turbos
    Sep 17 2006
    07 cbr600
    i like this. BF website says supports up to 400hp
    does it come with the hoses?
    Sep 11 2007
    Dirty Jersey
    mine did cause I got mine used, but if you buy it new it comes with just the intercooler, I'd use a set of zena racing hoses if it didn't already come with them (stockers fit too though)
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    idk about 400HP, but I think it would work well up to an aggressive Ko4 setup.
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by gotaudi View Post
    Well his FS ad said he was using it with a GT30
    http://audizine.com/forum/showthread.php?t=202050
    Oct 30 2006
    B8 A4 Avant 6spd
    Yeah I agree, I don't think this would fare well with a GT28 size turbo. It would heat soak real quick.
    -18 718 GTS
    Sep 11 2007
    Dirty Jersey
    the guys at boost factory seem to think it is and thats good enough for me, I will probably never see that big of a turbo on this car anyway seeing as its my daily and mpg is the biggest deciding factors in modding it, that and its FWD too
    Mar 09 2004
    nw michigan.
    Quote Originally Posted by Vreihenmotor6 View Post
    You'll get better mileage out of a larger turbo than a smaller one. The air travels through the engine with less resistance which yields higher efficiency.
    Jim
    I Do Werk.
    Sep 11 2007
    Dirty Jersey
    I'm sure having a lighter wallet would help too, aside frrom the efficency argument I simply cannot afford a big turbo
    Feb 26 2006
    Earth
    Quote Originally Posted by Militant-Grunt View Post
    Nope, sold alot of these to GTI boys running GT3071R and up.
    Look @ the size of the core.
    Sep 11 2007
    Dirty Jersey
    600 mile update:
    average MPG decrease : negligable (this is very important to me) I still get well over 30mpg on the highway
    things I've noticed:
    its really hard to stay in vac under partial throttle now, personaly whne on the highway I try to stay in the highest vac possible for economy, however due to what I can only assume is a much better flow effiecy my intake mainifold will almost instantly go to atomospheric pressue or beyond with the slightest pressure on my right foot
    I have a hard time knowing for sure (I don't have an outside air temp sensor readout :banghead: ) but it looks like intake air temps stay within about 20 deg F from aimbient
    I do however have real time in car intake air temp display and I can tell you that the intake air temps stay very consistant even under hard driving
    one neat thing that I did notice is as soon as the manifold hits atmospheric pressure or higher I seen a instant 4 to 6 deg F reduction in intake air temps
    I found myself flooring it in 5th a bunch tonight seeing just how much the air temps would drop
    just after the throttle is lifted the air temps return to their orginal state, no higher
    I'm pretty impressed so far
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
